Jag R134a A/C issues
Old Aug 19, 2023 | 07:38 AM
motorcarman's Avatar
In all the conversion documents issued by Jaguar, they recommended ESTER based oil when replacing R12 to R134a.
Old Aug 19, 2023 | 07:53 AM
Childeric12's Avatar
Yes, I am aware of that but, I had replaced every component aside from the evaporator. I had flushed the evaporator 3 times so, I used PAG oil instead as none of the other parts had ever seen R12.
Old Aug 25, 2023 | 06:04 PM
Well! The fine folks at Fen Air got me my kit much earlier than anticipated! Instead of several weeks, they sent it a couple of days after I ordered it and it arrived today. Will be installing this weekend and hopefully, I can report back good news next week!
Old Sep 3, 2023 | 09:44 PM
I installed the Fen Air kit. No change. Pressures are better but still not cooling. This is the third time I have replaced EVERY component but the evaporator. So, it is coming out. Dash out job I am not looking forward to.
Old Sep 3, 2023 | 09:46 PM
Vee's Avatar
Vee
One question. Have you ruled out a malfunctioning control panel? Maybe it’s not sending the AC signal?
Old Sep 3, 2023 | 09:56 PM
Yup. I checked that. I wish it was that easy....
Old Sep 4, 2023 | 09:51 AM
For whatever reason....this morning she is blowing cold. 58 degrees coming out of the vents. Not sure why. Pressure looks fine on low side. Slightly high on high side. Hoses on low side are ice cold.
Old Sep 4, 2023 | 05:24 PM
  #28
UPDATE. It is now blowing 48 degrees out of the center vents at 2800 RPM and 65MPH on a 95 degree day. I don't know if it is possible to improve on that. That's pretty good given the temp outside.
Old Sep 4, 2023 | 07:09 PM
Vee's Avatar
Vee
I'd say that is absolutely perfect.
Old Sep 4, 2023 | 08:05 PM
  #30
Agreed! I am going to consider this resolved. BTW anyone wondering about the Fen Air upgrade; the company made it pretty easy. Everything mounted into place with virtually no problems. The Sanden compressor is much lighter, and was easier to move around and get into place. A separate bracket was included for the cruise control bellows to maintain the original mounting location. I mounted it but haven't tried the cruise control yet. They provided clear instructions on everything. I appreciate everyone's advice and ideas!!
Cobbler
Jul 1, 2021 08:24 AM
alynmurray
Aug 30, 2016 04:25 PM
Iconoclast
Aug 24, 2015 07:27 PM
razorboy
Sep 26, 2014 03:55 PM
1100me
Jul 25, 2014 03:39 PM
