Key Cutting & Programming
Old Apr 24, 2012 | 03:07 AM
adam699's Avatar
Originally Posted by lglamb
Hi. Guess I'm too new here to send private messages, so for now I'll just reply to the thread.
Adam, I'd like the info for your guy in ChicagoLand. Just bought a 2000 XJ8 VDP and so far it's only affliction is having just the one key. Checked dealers in a 2 hour radius for pricing, and that ain't happening soon.
Thanks,
Lowell
2000 XJ8 VDP, 1988 XJ6, 1986 XJS
stop me before I buy again
Call my buddy Stan 773-771-8686
Old Sep 26, 2012 | 11:58 PM
blackjagroadster's Avatar
Default Looking for jag key in LA
I am trying to locate someone in Los Angeles Area who can help copy a key for 1997 Jaguar xk8.
thanks
Old Sep 28, 2012 | 09:26 AM
Bill400's Avatar
Hello Blackjagroadster,
Obtaining a spare key is a little simpler if your know your key code.
Learning to decode is easy and fun. Go to Code reading "Tibbe" keys for Jaguar
Once you have your code, more options are available.
If PATS system (chip key) programming is required, but there is more than one way to skin that cat!
A note for X-Types and S-Types: you have six spaces, not eight and four different "cuts" not three as did the older XJ.
best regards
Bill
Old Oct 1, 2013 | 12:09 AM
Bill400's Avatar
Default Rekeying Ignition Lock
Ben at Keysinthepost.com says he can re-key the ignition lock.
If your lock becomes worn or damaged a replacement can be keyed to match, rather than replacing the door and glove box locks also.
He also makes replacement keys from key code or a photo.
Quality is equal to OEM.
best regards,
Bill
Old Oct 1, 2013 | 05:40 AM
plums's Avatar
Thumbs up keysinthepost.com
+1 for keysinthepost.com
Old Oct 3, 2013 | 08:46 PM
jagjunky's Avatar
i am all in on this as well.......will stay tuned......in
Old May 11, 2014 | 08:59 PM
jarhead's Avatar
I am in need of a second key. I live in central Florida. Does any one know anyone beside the dealer that can cut a key (I have the key). hank you!
Old May 14, 2014 | 05:30 PM
  #28
GrayGhost's Avatar
Try eBay. I bought a complete assembly for my 2004 S-Type for under $100.
Old May 14, 2014 | 06:13 PM
Cut for your car?
Don't forget the new member intro.
Old May 14, 2014 | 06:37 PM
  #30
lrichard's Avatar
Question DSParks
I live in Green Valley, AZ, just south of Tucson. I just purchased my first Jag, an XK8 convertible. I have one key and one remote. I need a spare. When do you suppose you will purchase the machine and do you project a turn around time to cut and program? Where are you located? Your price seems fair. I thank you very much, in advance for any information given.
lrichard aka Dick
Old Jun 13, 2014 | 09:26 AM
  #31
Ccharlie1's Avatar
"Lock Geeks", in Tampa cut me a new key for my '06 XK-8, and programmed it in about 45 minutes. (Involved his laptop, an interface, all plugged into a port to the left of my steering wheel). He charged $110 - the best price I have found.
Old Jun 13, 2014 | 01:58 PM
  #32
magnum454's Avatar
Is the fob the only thing that needs programming?
Old Jul 27, 2014 | 12:18 AM
  #33
GEORGIE PORGIE's Avatar
Default jaguar key copy & programmed
Any Jaguar key copied & programmed for $150 in North Hollywod on Burbank bld near Lankershim...
Old Jul 27, 2014 | 02:18 AM
  #34
Welcome to the forum GEORGIE PORGIE,
Old Jul 27, 2014 | 09:55 AM
  #35
jaguar jon02's Avatar
bluff city jaguar in memphis just cut me a key ($299) and charged another $150 to program it for my 1998 xj8
Old Jul 27, 2014 | 09:58 AM
  #36
anyone know if the key is matched to the transponder and computor or just to the transponder
Old Aug 31, 2014 | 11:07 PM
  #37
ServiceMasterD's Avatar
BTW, a little know trick for programming a 3rd key to S-type, X-Type, and 2004-2009 XJ....
You need 2 working keys.
Have all three (two programmed, one not) ready.
Put first working key in ignition then cycle key. Put second working key in ignition then cycle. Put third (unprogrammed) key in ignition and turn to crank position. Vehicle should take a second then start.
Voila! Extra key without paying me $145+ for programming.
Old Sep 1, 2014 | 01:08 PM
  #38
xjrguy's Avatar
This is very true, however this will not work on the first generation S-Type, [2000-2002] only on 2003 and later.
Trouble is, there are very few instances where one needs key programming and they already have two working keys.
Cheers,
Old Sep 1, 2014 | 01:31 PM
  #39
motorcarman's Avatar
Steve, Have you ever tried to configure keys to early S-Types with the 2 key method?
I heard that also but I have had luck programming keys to 2000-2002 MY S-Types using the 2 MASTER keys and then a replacement. When I worked at the dealer years ago my buddy had a Ford Pickup and learned that you could program keys that way so we tried it on a 2000MY S-Type and IT WORKED!!!!!!
We also had to program a key using the 'aluminum foil' trick to fool the KTM into thinking we had the 2 key minimum.
Be aware that only 2 keys configured to the car with WDS, IDS etc. will configure the 3rd.
A key programmed using the 2 key method will start the car but will NOT allow programming another key.
Up to 5 keys can be configured to one car. If you program key #3,#4,#5 then you must use Key #1 and Key #2 to program the keys.
Remember also that if you lose a key it still counts as 1 of the keys, so you can only have 4 on hand and the lost key will be #5.
You can erase ALL keys and start over but you need WDS, IDS etc.
bob gauff
Old Sep 2, 2014 | 03:42 PM
  #40
xjrguy's Avatar
bob gauff
We didn't even know about that programming method until the X-Type came out in early 2001. At that time we tried a couple S-Types and it didn't work. Frankly, I never tried it again, since the word from Jaguar was, that was not a function of the X200. If I should ever have an X200 with two good keys, I'll give it go again.
All other points are on the mark! Thanks for a nice explanation for everyone.
Cheers,
