The Mystery of the 91 Sovereign...
Old Jun 19, 2013 | 01:16 PM
Marco W. Kurek's Avatar
Unhappy The Mystery of the 91 Sovereign...
Hey everybody, Im Mark, and I have been working on this 1991 Jaguar Sovereign 4.0 for awhile now and i cant seem to get it running right...since august... lately i found out that it wont even start up unless i disconnect the coolant temperature sensor (very weird) I've replaced everything that might be causing it to stall, and when i do get it running i have to keep my foot on the pedal and then it starts popping through the intake, if i let go of the pedal, it stalls.... please help!
Everything here i replaced and checked...
New Fuel lines
New Fuel pump
New Fuel regulator
New Fuel filter
New Mass air flow sensor
New intake manifold gasket
New idle air control valve -(programmed)
New plugs & wires
Checked catalytic converter
Checked distributer
Cleaned throttle body
Cleaned injectors
replaced computer ECU
what can be causing it to do this?
Old Jun 19, 2013 | 03:30 PM
Thermo's Avatar
Veteran: Navy
Marco, from what you are describing, it sounds like you have 2 plug wires that are crossed and you are having a cylinder or two fire at the wrong times, leading to the backfiring through the intake. From there, it is possible that you have managed to get the timing off a little. The timing chain may have jumped a tooth and that is causing your problems.
Old Jun 19, 2013 | 07:31 PM
thanks for the response thermo, i will check this and fix it, ill report back soon
Old Jun 20, 2013 | 08:17 AM
rld14's Avatar
Also, you missed the one thing that'll stop an XJ40 in its tracks: a crank position sensor.
Old Jun 26, 2013 | 12:02 AM
Rld14:
I plan on taking a look at that! Could be the culprit
skyryder
Mar 25, 2016 08:18 PM
Steve10
Sep 20, 2015 12:27 PM
1964Daimler
Sep 9, 2015 11:20 AM
tberg
Aug 31, 2015 04:33 PM
