Need to remove an airbag from a st.wh. in Japan (I'm in Europe)
Old Oct 18, 2024 | 09:04 AM
Jaroslav Záruba's Avatar
Default Need to remove an airbag from a st.wh. in Japan (I'm in Europe)
Hi
Would anyone know of a service shop (or just someone) that would remove an airbag from a steering wheel so the steering wheel can be flown out of Japan?
I'd pay in advance, and I don't care about the airbag.
Old Oct 23, 2024 | 01:22 PM
Vee's Avatar
Vee
Would this be for an 08 XJR? You don't mention anything about the car at all, I'm not sure how we're supposed to help.
Old Oct 23, 2024 | 01:57 PM
Reading my post again I can see that it is not very clear that the issue is I need someone in Japan to do it for me. (I am in Europe. And because of the airbag it is not possible to ship the steering wheel.)
The procedure itself is not the issue, the geographic location is. I.e. I need someone with a screwdriver and an address in Japan.
Old Oct 23, 2024 | 09:26 PM
Vee's Avatar
Vee
Still not clear what Jaguar model you need help with, but I would recommend posting in the General Forums, Regional Section, then Other Areas.
Good luck?
Old Oct 24, 2024 | 02:37 AM
it is a steering wheel from XJ x350
traffic in those forums seems pretty low, that's why i didn't post there initially;
but i have just posted there too: https://www.jaguarforums.com/forum/o...8/#post2795920
Good luck?
thanks sir
Old Oct 24, 2024 | 12:19 PM
Vee's Avatar
Vee
Lastly, I would then post in the x350 forum! There's likely to be much more activity over there!
Old Oct 25, 2024 | 04:26 AM
Well that was what I wanted to avoid. I.e. I needed help with the "Japan" part of the problem, not specifically with x350. 😁
But it's heading in the right direction already. I got a contact in Japan already who agreed to do the job.
PC44
Jan 4, 2024 03:32 AM
Hyperboreer
Feb 23, 2022 06:53 AM
jay_987
F-Pace (X761) / C-X17
Mar 13, 2019 06:11 PM
8bit
Mar 27, 2017 11:00 PM
JRE-xkr
Dec 2, 2010 06:04 AM
