Noise from steeering wheel
Old Jul 12, 2009 | 07:53 PM
Louenigma's Avatar
Question Noise from steeering wheel
I noticed today as i drove in my driveway a swooshing noise coming from my steering column when i turn it slightly left and right.
ive heard of an additive that does the job.
please help
Old Jul 13, 2009 | 03:57 AM
There you go Lou.....hope that helps
MODEL
XJ, S-TYPE,
X-TYPE
DATE
24 AUG 2007
NUMBER
JTB00055
SERVICE
TECHNICAL BULLETIN
NOTE: The information in Technical Bulletins is intended for use by trained, professional technicians with the knowledge,
tools, and equipment required to do the job properly and safely. It informs these technicians of conditions that may occur
on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be
performed by “do-it-yourselfers.” If you are not a Retailer, do not assume that a condition described affects your vehicle.
Contact an authorized Jaguar service facility to determine whether the bulletin applies to a specific vehicle.
© Jaguar 2007 Page 1 8/24/2007
THIS BULLETIN REPLACES ALL VERSIONS OF ST211-004, XJ211-001, XT211-001
SECTION: 211-00
Power Steering System Squeaking Noise Repair Procedure
AFFECTED VEHICLE RANGE:
S-TYPE VIN: M45255 Onwards
Model Year: 2003 Onwards
XJ Range VIN: G00442 Onwards
Model Year: 2004 Onwards
X-TYPE VIN: C00294 Onwards
Model Year: 2002 Onwards
CONDITION SUMMARY:
POWER STEERING SYSTEM SQUEAKING NOISE
Situation
: On some S-Type, X-Type and XJ Range vehicles within the VIN ranges above, a
squeaking noise may be apparent from the power assisted steering system when the steering wheel is
rotated in either direction. The noise is caused by a seal inside the steering rack. The noise can be
transmitted through the steering column and steering wheel, making it difficult to diagnose.
This bulletin does not address any other PAS noises, such as pump or drive belt related noises.
Action
: In the case of a verified customer complaint matching the description above, refer to the
Repair Procedure detailed in this bulletin and complete the service fix.
PARTS:
C2S 48887 ...............Fluid additive Qty 1
WARRANTY:
NOTE: Repair procedures are under constant review, and therefore times are subject to
change; those quoted here must be taken as guidance only. Always refer to DDW to obtain the
latest repair time.
DDW requires the use of causal part numbers. Labor only claims must show the causal part number
with a quantity of zero.
Description SRO Time
(Hours)
Condition
Code Causal Part
PAS Squeak/Fluid Additive
57.91.29/01 0.2 42 C2S 48887
Normal warranty policy and procedures apply.
Old Jul 13, 2009 | 11:06 AM
Louenigma's Avatar
Thumbs up
Thank you very much Jim !
will make appointment soon at my jag dealer.
Old Jul 23, 2009 | 09:24 PM
RickMG's Avatar
I looks like you don't have to take it to a dealer, just buy the fluid and follow the rest of the instruction. Here's the entire instructions from the X-Type Faqs section.
http://jim.customer.netspace.net.au/...0Procedure.zip
Old Sep 25, 2009 | 07:01 PM
Louenigma's Avatar
Thumbs up
Again many thanx for the help.
i love this forum
Old Oct 16, 2010 | 08:50 PM
steve11's Avatar
ud
Dexron III is the spec. Use Dex VI or Dex/MERC either will exceed manufacturer's spec.
Rivguy
Dec 4, 2020 07:55 AM
PMKimpton
Aug 3, 2019 08:22 PM
sawduster
Sep 11, 2015 10:02 PM
raulan
Sep 10, 2015 12:43 PM
innzane
Sep 2, 2015 10:08 AM
