OBDII Code Scanners ** Member Approved **
Old Jan 26, 2023 | 11:11 PM
  #601
xalty's Avatar
Originally Posted by Hooli
I've got lost in this thread, so much info over the 12 years or so it's been running.
Is there a current recommendation to use on a X308?
I was thinking of this https://www.ebay.co.uk/itm/384979812...id=27038347467
VIDENT iAuto 702Pro
As recommended further up the thread, is that still a good idea?
get a thinkdiag. and a throwaway android tablet if you're an apple user
Old Jan 30, 2023 | 02:44 AM
  #602
Hooli's Avatar
I'll take a look cheers
Old Jul 4, 2023 | 12:59 PM
  #603
848tse's Avatar
Default Any advice on scanners?
Hi all,
Hoping someone can help with obd2 scanners. I have a 2006 XK, and have the dreaded check pedestrian system light on. Have had it checked and it is unsurprisingly one of the sensors, but, I can't remember if it is left or right (which is 100% my excuse to buy a scanner!) From what I have read, the RH sensor will be a B1004nn code, the LH sensor will be a B1005nn, but I'm not sure what scanners can pick up on Body codes, does anyone have any experience with this? Also, my better half has a RR Evoque, so if there is one tool that can do both in case her car needs any attention, that would be a bonus.
Thanks in advance!
Old Aug 9, 2023 | 05:45 PM
  #604
JohnNZ's Avatar
Default Latest Recommendation for 1997 XK8 Please
Hi,
New member here - but not new to XK8.
I'm looking for a good scanner for a 1997 model.
Considering the icarsoft CR V2.0 or similar - which I believe are the later versions of previously recommended icarsoft models.
But do they work for all modules on these earlier cars?
I have an Autel MD 801 which doesn't do much.
I also have a vxnano J2534 but haven't had much luck with the IDS/SDD - are there any recommendations/downloads for going this route?
Thanks in advance for any help.
John
Old Aug 11, 2023 | 10:00 PM
  #605
John R Parker's Avatar
Originally Posted by eaglexkr
I have the TOPTQK 280 that I use on my 2000 XKR.Reads the codes just like it should.
Have owned my 1999 XKR convertible for 12 years and use TOPTQK280
Old Aug 12, 2023 | 01:38 AM
  #606
JohnNZ's Avatar
Hi,
What is that?
When I paste TOPTQK280 into google, there's only 3 Results!
One on this forum and the other two irrelevant....
Old Aug 12, 2023 | 01:42 AM
  #607
JohnNZ's Avatar
OK, with a space in it - TOPTQK 280, I understand now.....
How many modules can you talk to with it?
Can you see ABS? IC? BCM?
Or is it just engine & trans?
Thanks, John.
Old Aug 12, 2023 | 07:03 PM
  #608
Thanks, John.
Hi I live at Mount Maunganui and have been engaged in Automotive spares for more than 60 years. The TOPTQK TP280CAN that I have quotes.This OBD-11 code scanner is designed to read and clear vehicles DTCs and Pending DTCs, retrieve Freeze Frame Data, live data and vehicles information, check vehicles monitor status.Since it supports all OBD-11 protocols: ISO-14230 ( KWP2000 ), J1850VPW, J1850PWM and CAN bus , you will be able to use it on any 1996 or newer car.
NB, TP-280CAN is updatable via the internet for future vehicles ( This is on page 21 of the user manual , I have not used this feature ) I purchased this unit because at the time about 12 years ago it was very difficult to find an OBD11 reader for Jaguars prior to the year 2000 ( My car is a 1999 XKR convertible ) Appart from the security locking control module requiring major surgery ( internal resoldering ) this car has been trouble free. I do have most of the special factory tools for this car and they proved their worth when I replaced the early tensioners and chains. I also hold a comprehensive range of new spares for this Jaguar, Hope you find this helpful. This car is my hobby and as such wants for nothing, Cheers John P
Old Aug 12, 2023 | 07:32 PM
  #609
JohnNZ's Avatar
Thanks for a good reply mate.
I didn't explain well - but there are a couple of reasons I asked "Which modules you can see on it"
One reason is - I have 4 other scanners including an Autel MD 801 'MaxiDiag' which is supposed to do everything but just does engine & trans.
And a vxnano J2534 but haven't had much luck with the IDS/SDD.
The other reason is the early 1997 cars are a bit 'primitive' in their electronics. So stuff which works on younger cars might not on this.
So I'm not asking about engine/transmission stuff which my other scanners will read.
But I really want to know about ABS, Aircon, Instrument pack, Body Control Module, Security module, Door and seat modules etc.
Modules labelled IPK, BPM, SLH, DDM, PSM, etc - modules which I can't read and don't know what will.
Sadly I've bought a few scanners that promised the advanced stuff but were pretty basic.
And I don't want to drop $400 again doing the same ....
Thanks for any help.
Old Aug 12, 2023 | 08:29 PM
  #610
JohnNZ's Avatar
John Parker said --- Appart from the security locking control module requiring major surgery ( internal resoldering )
Did you diagnose this fault with your scanner John?
Old Aug 13, 2023 | 04:15 PM
  #611
Sadly I have to report the TOPTQK-280CAN reads everything engine wise, anything fuel , Coolant temp,vehicle speed, air intake temp, throttle position, oxygen sensor value,RPM & transmission but none of the others you list. The SLCM resolution was arrived at by a process of elimination and cost $500 whereas a new SLCM that I managed to get JLR to reinstate in their system ( They had the blanks at that stage unprogrammed for my car ) cost was estimated at $3600.Via my contacts $2200.
This reader cost me $85.83 plus freight $36.76 a total of $123.59 . Good value to have in the boot however seldom used as my car has been reliable due to prevenative maintenance. Sorry I can't be of much more help. I have found a true Jaguar Majician boffin here at the mount and he now looks after the car. cheers jrparkerstag@gmail.com
Old Aug 13, 2023 | 04:24 PM
  #612
JohnNZ's Avatar
Thanks for making an effort on this John.
I've just bitten the bullet on a $420 icarsoft CR Pro.
Ozbot on the X100 forum said it does all those modules on his 1997 model.
I'd like to get my VXnano cable going - which is suppose to do programming as well,
it's a version of the oem/mongoose style things.
I've got the thing it'self going on the computer, but haven't figured out how to coordinate it with IDS/SSD...
Old Jan 7, 2024 | 11:44 PM
  #613
ForTheLoveOfCars's Avatar
Originally Posted by 95xj12
I have an Innova 3120, while it reads the codes in my 95 xj12 as generic (but still yet accurate), it doesnt seem to be clearing the check engine light?? I dont know whether its me or what though? It showed a p1441...and I changed out the purge valve, the code still shows?
i have the 3170rs and it doesnt clear the codes on my 01 XJR but works great on my X type
Old Jan 15, 2024 | 07:04 AM
  #614
Joons's Avatar
Autel MD806 does not work with 2005 STR https://www.autel.com/mk2/3193.jhtml
Old Jan 29, 2024 | 08:34 AM
  #615
Joons's Avatar
iCarSoft LR V2 for Land Rover Jaguar works with 2005 S Type R
Old Apr 10, 2024 | 02:44 PM
  #616
AVRO XJS's Avatar
1996 XJS 4.0 Celebratino coupe UK spec RH drive. OBD code reder recomendation request.
New-ish to the forum. I don't see any recommendations for a code reader for the XJS or the XJ6 (x300) both have the OBD port. I did pull some codes of my !996 XJS with a cheep eBay reader but not enough info for my needs. Any recommendations ?
I am considering Scan tools OBDLINK MX+Pro for £139.00 will work with iPad iPhone PC Laptop. This will work with my Jap daily drive but not sure it will work with the 1996 vintage Jag.
Tig
Old Apr 12, 2024 | 08:08 PM
  #617
Thermite's Avatar
Tig
The older the vehicle, the leaner the info to be had. Scanner can't display what was not provided.
"Basic" OBDC (2) was/is largely a core set mandated by Government rules and industry's response to them, "brand immaterial", so most any scanner newer than the vehicle Model Year can display those.
More capable and "marque-specific" firmware & software scan tools also retain the basic OBDC mode, so are not overkill as an investment.
From there, "it depends" as to vendor-specific modules and features, 'live data' stream, trims, resets, and calibrations, on whether one adheres to one marque or family, or needs to cover several.
"Mostly firmware" stand-alones, such as both of an iCarsoft i930 and the more-capable iCarsoft V3 serve my choice of JLR's (see sig, below). I don't expect to have to accomodate anything else, let alone "newer".
"Mostly software" units that run an "App" on a third-party smartphone, tablet, or notebook and/or depend on an internet "cloud" or subscription service are not necessarily limited to any one marque. Their limits are set by how comprehensive a coverage their maker is able to keep up with. And on that supplier remaining in the business at all, of course. Not all have done, so their products can become unsupported "orphans".
Older, established brands may be less of a dice-roll than newcomers - features or claims-of quite aside.
In addition to "user approved" one can search the 'net for "problems with...<brand & model>".
Not a BAD idea to run such a search on ANY planned purchase.
CAVEAT:: Bad news always travels fastest, and nowadays 'widest', even 'silliest', so don't be surprised to hear that your faithful clothes washing machine has been blamed by some OTHER fool for mass starvation in the Arctic sea.
"Grain of salt.." etc.
Not to worry. Everything in our lives risks obsolescence.
We tend to pay the money then JF deal with that, as death and taxes are still as reliable as ever were.
Old Apr 13, 2024 | 03:35 AM
  #618
AVRO XJS's Avatar
Thank you for the advice. The internet is a great resource but not every thing that glitters is Gould. I will check out some of your recommendations, Like you I do not see me buying anything newer than my 17 year old Suzuki daily better, or newer than 1997 Jag, So no need to opt for all singing tool.
Regards
Tig
Old Apr 13, 2024 | 10:50 AM
  #619
kkurulak's Avatar
So, I have purchased and have been playing with the Launch X431 Creader Elite JLR version and I must say I am extremely disappointed. It seems that every feature has either an add on cost you must subscribe for or once selecting a feature, it pops up a text box giving you instructions how to manually perform the task you have already been performing like every other google search or posts here will.
For example, thinking that one of the features is the "Simple and easy reset of service functions" would be one click of a button, but it is not, after following the pathway to the final option, it pulls up a text box explaining the manual reset of the fog light and trip buttons, something I was trying to get away from as how sensitive it can be when resetting.
If anything, spending more than $50 on this unit is far too much and only opens the door for more expenses one must pay to access information you might already know and have been previously performing.
Old Apr 16, 2024 | 02:08 AM
  #620
Thermite's Avatar
Originally Posted by kkurulak
...Launch X431 Creader Elite JLR version and I must say I am extremely disappointed.
More than 13 years already since this thread was begun by another helpful contributor, and it is still adding value.
I bought hte iCarsoft i930 to use on the 2005 XJ8-L off the back of positive reviews, right here. Haven't yet had cause to regret that.
When the newer 2011 Range Rover Sport wanted a scanner (as I keep one IN each vehicle), the iCarsoft V3 was a logical choice, and that one has given me good service (and more features), too.
There are more capable scan tools, but as neither of the iCarsofts I mention requires a "Mothership" device running Android, Apple, or WinWOES on a "smart" phone, tablet, notebook, laptop, or a "subscription", their all-in-one self sustaining head is easier to use and more than good enough for my needs, "calibrations" included.
