P2098, fuel trims inside
Old May 23, 2015 | 06:20 PM
ddillenger's Avatar
Default P2098, fuel trims inside
Patient is a 2007 Range Rover Supercharged, 4.2, AJ33 v8. Same as your XKR's presumably
Recently I got a CEL. Fault code returned was P2098, Post catalyst lambda control system too lean, bank2 (or something to that effect). I figured, ok. It's got a leak! YAY! Broke out the smoke tester, smoke tested the system, no leak. For good measure (and because I didn't realize how loud the PCV system on these is) I replaced the PCV valve. Next, I replaced both of the post catalyst lambda sensors, ensured I had no exhaust leaks, and while I was down there installed a magnaflow exhaust.
Anyway, it has now been approximately 700 miles with no CEL, but my fuel trims still look a little wacky:
and
From what I gather the post catalyst sensors are working properly and reading all as A-OK, but something still is not right. I have yet to do a full tuneup, but that's next on the list. Was just hoping for some insight
Thanks guys!
Matei Dima
Oct 8, 2015 11:45 AM
RoyLittle0
Sep 17, 2015 01:05 PM
mrplow58
Sep 14, 2015 08:30 AM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
