Range Rover seatbelt warning stopped
Old Jul 6, 2014 | 04:50 PM
joealas's Avatar
Default Range Rover seatbelt warning stopped
How do I reactivate the seatbelt warning bell. It stopped sounding?
Old Jul 6, 2014 | 05:34 PM
Welcome to the forum joealas,
This is a Jaguar (and not a JLR) forum but some members also run Range Rovers and may be able to help you.
Old Jul 6, 2014 | 06:11 PM
Thermo's Avatar
Veteran: Navy
If it is like other Ford products (you don't state what year your Rover is), try turning the car on to the RUN position (do not start the car) and then buckle and unbuckle the seat belt 5 times in quick susession. That should cause the computer to re-enable the seat belt reminder.
Old Jul 6, 2014 | 09:51 PM
Cambo's Avatar
What year Range Rover? Which model?
My 2008 Land Rover Freelander uses a slightly different method to turn off the beltminder
1) Insert the key fob
2) Press and HOLD the start button without your foot on the clutch (manual) or brake (auto) for about 2-3 seconds
3) Insert and remove the seat belt 9 times - a chime will sound on the 9th attempt
4) Seat belt warning is disabled
No idea if it will work, but all the Ford family cars use a similar method.
JarodL
Mar 7, 2024 01:39 AM
Jpav27
Jul 31, 2022 06:43 AM
johndahlheimer
Sep 16, 2015 05:44 PM
Jaguar Forums Editor
Jaguar Press release
Sep 10, 2015 05:08 PM
