refueling S Type 2003
Old Sep 29, 2023 | 01:15 PM
Donald Jordan's Avatar
Default refueling S Type 2003
when I attempt to put fuel in my 2003 S Type, the gas hose keeps shutting off as if the tank is full. I have to click the handle and start to fueling again and again until finally its full. What is the problem and how do I trouble shoot the issue.
New Mexico Jag
Old Oct 1, 2023 | 12:07 AM
Thermo's Avatar
Veteran: Navy
Donald, from the sounds of it, your fuel vapor canister solenoid is failed and it is not venting your gas tank. That will cause a pressure to build up in the gas tank, triggering the gas pump to turn off. Common issue with cars with some age on them. In short, the charcoal canister back by the fuel tank has a solenoid that opens and vents the gas tank. The gas vapors get trapped in the canister so they do not polute the environment. i want to say the solenoid is like a $50 part and fairly easy to replace. The big thing is accessing it on the vapor canister.
joycesjag
Aug 9, 2021 09:56 AM
Rogelio Serrano
Nov 22, 2019 12:30 PM
austino
Dec 18, 2017 02:42 AM
