Removing front top bar above radiator 2001 jaguar X
Hi, i have a leaking radiator / hose or whatever at top of radiator area - cannot identify exact location and cause as under a metal cross bar above the radiator.
Is there a simple way to remove the cross bar as appears to have multiple bolts etc on top and top sides of engine bay?
Charlie, id you look at that support beam, you should see 2 holes that have the posts from the radiator. Then you will see 3 bolts on each side. Remove those bolts and the bar should come out and free up the space you need.
Man on the hill
Jul 15, 2017 08:17 PM
