Removing front top bar above radiator 2001 jaguar X
Old Mar 4, 2023 | 12:02 AM
Charlie Farley's Avatar
Default Removing front top bar above radiator 2001 jaguar X
Hi, i have a leaking radiator / hose or whatever at top of radiator area - cannot identify exact location and cause as under a metal cross bar above the radiator.
Is there a simple way to remove the cross bar as appears to have multiple bolts etc on top and top sides of engine bay?
Old Mar 4, 2023 | 07:55 AM
Thermo's Avatar
Veteran: Navy
Charlie, id you look at that support beam, you should see 2 holes that have the posts from the radiator. Then you will see 3 bolts on each side. Remove those bolts and the bar should come out and free up the space you need.
Old Mar 4, 2023 | 07:06 PM
Roger that ta - will try that
robbing
May 3, 2024 08:29 AM
EsRay
Aug 5, 2021 05:07 PM
Kansan
Jun 17, 2019 07:45 PM
Man on the hill
Jul 15, 2017 08:17 PM
kenbowen
Mar 30, 2016 09:09 AM
