Restricted performance
Old Feb 5, 2023 | 02:44 PM
gmarand11's Avatar
Default Restricted performance
Every couple of weeks or so, I get a 'Resricted Performance' notification on my 2015 F-type 6 cylinder. If I turn off the ignition and then start it back up the notification disappears and the car runs normally. Any thoughts?
Old Feb 5, 2023 | 03:36 PM
NBCat's Avatar
What is the available battery voltage with the ignition in the OFF position when checked with a voltmeter across the terminals?
Old Feb 6, 2023 | 05:49 PM
gmarand11's Avatar
Hi
For whatever reason my voltmeter is not working but the battery in the car is new. I forgot to mention that the check engine light also comes on occasionally but not at the same time as 'restricted performance' and usually stays on only for less than a day.
Thnx
Old Feb 6, 2023 | 06:00 PM
gmarand11's Avatar
Got the meter working- 12.6 volts
Old Feb 6, 2023 | 06:28 PM
NBCat's Avatar
If the MIL is on, what DTCs are stored or pending?
12.6 volts is the necessary available voltage for systems to function correctly.
Old Feb 7, 2023 | 01:36 PM
gmarand11's Avatar
When I performed a ODB II scan there is nothing
cdma
Oct 1, 2022 01:19 AM
dcdecs
Feb 3, 2015 08:04 PM
