SDD help on programming CFF and updating firmware for amp.
Old Jun 10, 2021 | 07:26 PM
tpsr44's Avatar
Default Need help programming the amp on a 2012 Range rover L322 autobiography ultimate edit
The original amplifier was broken. I bought a new one from Land Rover and following installation all functions from the entertainment system were restored except the sound.
I tried to program it using SDD version 160.02 v342, but go the below error message:
can anybody please help on how to fix this. I am tired of singing to myself while I am driving
My old amplifier pic is below. I replaced it by a similar one.
Old Feb 6, 2023 | 05:26 PM
Ceee.Rock's Avatar
Default Please my audio amplifier stopped working while trying to update firmware.
Originally Posted by enzofl2
Let me know which version of sdd you use.
Let me know which version of premium Amp you use.
Let me know which original version of Highline Amp was born with the car.
Let me know the model and year of registration of the car.
So let's try together to reprogram the premium amplifier firmware. Ok?
Give me time to help, because I'm inundated with work, but I will do everything I can. We hope well
Please my audio amplifier stopped working while trying to update firmware. I’m using launch pad vii
Old Feb 6, 2023 | 05:55 PM
Hamedhbb's Avatar
upload a photo of the new unit if you are still struggling.
Old Nov 24, 2023 | 04:48 PM
corn's Avatar
Default Mediriam up grade
Hi all I've changed the amp all the speaker and it's all wired in my 2012 xf it had the 600w jag system which was terrible, my mate changed the ccf to premium but I only have dolly and dts on the screen mediriam isn't showing in audio setting is there something els I need to do ? Or do I need the head unit from the same car thanks corn.
Old Jun 16, 2024 | 07:50 AM
G.K's Avatar
G.K
Question Same situation No Audio / No sound
Hello,
I'm in exactly the same situation.
I have no sound.
My amp is the model:
BJ32-19C164-AG
When I try to configure it, it finds the model:
BJ32-14C526-AG
I get the same error.
A failure occured....
So no sound.
Maybe one people have the vbf file?
For the model:
BJ32-19C164-AG
Old Jun 16, 2024 | 09:35 AM
corn's Avatar
Default Up grade
Originally Posted by G.K
Hello,
I have no sound.
BJ32-19C164-AG
BJ32-14C526-AG
So no sound.
For the model:
BJ32-19C164-AG
what year and system is in yours ?
my amp ends in BG not AG has you car got a sub as standard? If not you need to change the green plug for the higher grade amp
Old Jun 16, 2024 | 10:00 AM
G.K's Avatar
G.K
Many thanks for your help !
the system dates from 2013 / 2014 i believe the system in BG is the model above
My car is actually equipped with sub as standard.
I think my amp works but it's the update that can't install.
Old Jun 16, 2024 | 10:04 AM
  #28
corn's Avatar
Send me a pic of the old amp.
Old Jun 16, 2024 | 10:06 AM
corn's Avatar
Is this plug fitted in the bottom left of the boot
Old Jun 16, 2024 | 10:08 AM
  #30
corn's Avatar
You can't set up meridian in a face lift only bowers settings for the surround just so you know. Well we couldn't
Old Jun 16, 2024 | 10:17 AM
  #31
G.K's Avatar
G.K
it's still my old amp
To clarify the situation, I updated my sofware amp and got an error: my configuration hasn't been modified or changed, it's my original amp.
I'm trying to reconfigure it because it's no longer detected by my system.
Old Jun 16, 2024 | 10:24 AM
  #32
corn's Avatar
Why update it ? It should never need up dating ? I just changed the amp to the mediriam one put the surround sound in changed the door speakers to meridian and changed the settings to premium. That was it. I know people who have played with changing the software and it bricks the amp. Il see if I can find more on it. Someone managed it to do but not sure if that was just luck. You do have battery supply running while using SDD ?
Old Jun 16, 2024 | 10:31 AM
  #33
G.K's Avatar
G.K
Unfortunately, I was stupid enough to do the update, which caused me to lose the sound
Ok I understand better your change which is different from mine.
If you have a solution I'd be extremely grateful
yes i have battery supply running while using SDD, the module is well recognized, but impossible to reconfigure.
Old Jun 16, 2024 | 10:34 AM
  #34
corn's Avatar
https://www.jaguarforums.com/forum/a...-14c526-ba.rar
look at this should shed some light on it hopefully
Old Jun 16, 2024 | 10:35 AM
  #35
corn's Avatar
That's the firmware someone else used
Old Jun 16, 2024 | 10:37 AM
  #36
corn's Avatar
Old Jun 16, 2024 | 10:38 AM
  #37
corn's Avatar
https://www.jaguarforums.com/forum/x...-wrong-221956/
this is the thread I went through. Other wise new amp.
Old Jun 16, 2024 | 10:52 AM
  #38
G.K's Avatar
G.K
Thanks again,
I also read this article, I'm going to try with the file you sent me to see if I can update by renaming the file.
Old Jun 16, 2024 | 10:59 AM
  #39
corn's Avatar
No worries hope you get it fixed
Old Jun 16, 2024 | 11:15 AM
  #40
G.K's Avatar
G.K
I have try to rename DX23-14C526-BA.vbf to BJ32-14C526-AG and start the update i have an error too, if you have another idea
