starting system voltage
Old Dec 16, 2023 | 01:30 PM
ottenkor's Avatar
Default starting system voltage
Working on jaguar e pace 2018
car does not start and does not crank.
startup battery shows 12.8 volts at terminals.
startup battery fuse is good
green wire coming out of the battery monitoring sensor shows 7.8 volts. This is the wire going into the BCM.
Have not checked the alternator yet because I'd like to rule out the sensor and the BCM first. Alternator is hard to get at.
Is this green wire supposed to be showing 12 volts or is 7.8 normal?
Boletus
Apr 18, 2022 06:34 AM
dh53
Oct 5, 2021 03:56 PM
Dave Greco
Nov 21, 2020 05:41 PM
Elvo47
Apr 15, 2015 01:46 PM
buddyluv
Jul 25, 2012 01:12 AM
