Swapping out a diff, what's easiest way?
Old Aug 22, 2021 | 03:01 AM
rich333's Avatar
Default Swapping out a diff, what's easiest way?
I want to swap out the diff on a custom with a Jag rear axle.
Is this just a case of dropping the old diff out and putting the new one in or are there any special tools I'll need or any alignment procedures?
The diff I have to put in has the brake assemblies on, so it's probably eaiser to keep these fitted?
It also has the inner fulcrum mounts on, so again, keep these on? I see these are shimmed so do I need to accurately measure the old diff width or shim thinkness to make sure I keep the alignment right?
I am thinking it's going to be easier to drop the whole axle assembly from the car and replace the diff rather than trying to do it in-situ.
Any suggestions welcome.
Old Aug 22, 2021 | 05:14 AM
Fraser Mitchell's Avatar
There are shims for two things, (1) disc alignment in the caliper, and (2) wheel camber adjustment. If the brake assemblies are already on, then you don't have to align for the discs, just the camber angle.
Old Sep 14, 2021 | 02:53 AM
rich333's Avatar
Anyone see any immediate issues swapping over these diffs?
The one currently installed has smaller brake disks.
I am thinking that I will swap the diff and brake assemblies over.
As long as the width between the drive shaft flanges remains the same (by adding or taking out shims) I should be good?
The top mounting angle appears to be the same on both.
I don't need the handbrake on the new diff but I don't see why I can leave the mechanism on, if it still fits in under the car. (hydraulic handbrake)
MPDano
XJ40 ( XJ81 )
Aug 12, 2021 10:02 PM
Willafizz
Jan 21, 2021 01:41 PM
Sterlingcousins
General Tech Help
Jan 14, 2014 07:56 AM
JaguarXKR
Feb 25, 2013 07:44 PM
popeye68
Oct 7, 2011 09:33 AM
