Unknown Vacuum line
Old Dec 12, 2020 | 06:12 PM
Desertdawg's Avatar
Default Unknown Vacuum line
My '98 XJ8, new cam chains/tensioners/guides.
I don't know where this tiny plastic tube goes. It comes from this sensor assembly (?) With the 2 yellow caps,, next to the brake booster. It must tie into the vacuum system. Can I tee it into a common vacuum line?
Old Dec 12, 2020 | 06:44 PM
motorcarman's Avatar
There should be a vacuum reservoir under the air filter housing.
All part of the AJ26 speed control.
Old Dec 13, 2020 | 02:53 PM
Desertdawg's Avatar
Default Found it
You're right, one line does go under the air cleaner.. That was already connected,, but I found the unknown one had broken free from the tee connection beneath the sensor just behind the throttle body. I used some clear tubing from Lowes to make the broken connections in a couple places. See pic. Thank you!
Treozen
E type ( XK-E )
Oct 16, 2020 06:08 PM
CZSteve
Sep 27, 2020 11:02 PM
Daniel98
May 28, 2020 12:22 PM
Chris Bonner
Sep 12, 2019 04:00 AM
