Updating Radio
Old May 7, 2013 | 11:15 AM
Terry's Avatar
Default Updating Radio
It appears that the AJ8700 radio in my XJS has died. I really like the simplicity of operation of the radio and to my old ears the sound is very adequate. I got to thinking that if I'm gonna replace it, maybe a radio out of a later model Jag would fit right in there and have a few more features. I really like the simple two knob type of operation. Is there a later model factory radio that sounds better, is cd capable etc, but, has the ease of operation I'm looking for.
I really dislike the new aftermarket radios with the multi function buttons. I don't want to go that route unless I have to or can find one that is very user friendly.
Old May 9, 2013 | 03:00 AM
If you like the original look but want up-to-date features, this could give you some ideas:
Classic Car Stereo - Vintage and retro style car radios and speakers
A popular option here in the UK, there must be US suppliers of similar products.
Old May 9, 2013 | 10:04 PM
xjrguy's Avatar
Give the folks at United Radio a call, numbers are on the form. They can reman your radio for two or three hundred bucks. Then you'll be back in business!
http://www.unitedradio.com/docs/af72-01d.pdf
We've sent radios to them for repair several times; comes back looking like new.
Cheers,
Old May 10, 2013 | 10:04 AM
Terry's Avatar
Thanks guys,
I have solved the problem. I pulled the radio out to check voltage at the plug and found another fuse. It is a push in plastic type and it is inserted into the top of the radio. I don't know if they all have this fuse, but, nobody mentioned it in the initial responses. Mine was under a piece of clear tape and easily visible!? Maybe they are sometimes covered with some other kind of tape? Anyhow, the fuse was blown, I replaced it and all is well. I must have blown it when I blew the antenna fuse screwing around with the antenna wiring.
I will check into the Vintage style sites and see what I can find. I'd like a couple more features, but, ease of operation is more important to me.
Terry
oldjaglover
Dec 25, 2024 04:33 PM
Paora
Feb 4, 2021 12:36 AM
bdboyle
Sep 16, 2019 05:58 PM
philwarner
Jan 31, 2016 09:36 AM
