Wheel vibration
Old Jul 10, 2016 | 03:14 PM
genelavine's Avatar
Default Wheel vibration
I have a slight vibration in my steering wheel, like there is a tire out of balance. I had the wheels checked and the wheels are straight and in balance. Still vibration. Any ideas. My car is a 2012 Jaguar XJ Basic L.
Never been in any accidents.
Thanks,
Gene
Old Jul 10, 2016 | 03:43 PM
Pa.Bill's Avatar
this at all speeds?
Wheels are straight and balanced.... How about a tire 'out of round'?
Old Jul 10, 2016 | 03:50 PM
genelavine's Avatar
Checked that also. New tires and they are round.
Old Jul 10, 2016 | 05:02 PM
Pa.Bill's Avatar
What is left................. Shocks
and the last thing that came to mind is-- all wheels ( lugs) tighten down properly?
All tires are the same?
It got to be something simple.
Also thinking about air pressure to balance out the car.
Old Jul 11, 2016 | 09:42 PM
Vector's Avatar
You can "balance" a football on a regular wheel balancer, but it won't run true.
Get a Hunter Road Force balance job done by a good tech, make them check the runout on the wheels and tires too, do everything the machine can do to check the wheel/tire combo, then see if you still have the issue.
My guess is you DO have a slightly bent wheel, but without the proper equipment to check it, you will never know.
Anyone who tells you they can "eyeball" a bent wheel is fooling themselves.
Vector
Old Jul 12, 2016 | 06:18 AM
genelavine's Avatar
Thanks for the insight.
Gene
