XJ 3.0D 300PS Turbo Actuator Stuck High (Restricted Performance)
Old Apr 24, 2021 | 01:29 PM
zYx's Avatar
zYx
Exclamation XJ 3.0D 300PS Turbo Actuator Stuck High (Restricted Performance)
As I was pushing down the motorway earlier today I got the first performance issue since I bought the car 6 months ago. It's a 2016 XJ 3.0D 300PS engine with 54k miles.
I carried on driving for another 30 miles, parked the car, went shopping and when I returned to the car about 45 minutes later, the message was gone and the car performance was back to normal.
I'm no mechanic but when I got home, I plugged SDD in and I found two DTCs:
  • P259B-71 Turbocharger boost control position sensor B performance - Stuck High (actuator is stuck)
  • P004B-77 Turbo/supercharger boost control solenoid B - circuit range/performance (commanded position not reachable)
I'd appreciate your expert opinion and whether it's something that I can "fix" to prevent this from happening again. Can I repair the solenoid/actuator, replace it without going down the turbo route?
Also, what could be the cause of this? Not sure if related, but I normally use standard diesel, and I have recently filled my car with premium diesel and the last two occasions.
Many thanks
Old Apr 24, 2021 | 05:00 PM
Fraser Mitchell's Avatar
Might be better if you repost this in the X351 forum.
Ash
Jun 29, 2022 03:38 AM
robdos
Aug 28, 2019 11:47 AM
bradburygroup
May 26, 2018 05:06 AM
Nigelw67
Jul 24, 2017 06:09 PM
Bridge
Apr 21, 2012 01:56 PM
