Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
Sponsored by: CARiD
Cleaning caramel interior?
Old Jul 11, 2010 | 06:39 AM
GrahamS's Avatar
Default Cleaning caramel interior?
Does anyone know of a product that will shift the black shoe scuff marks from the caramel plastic trim pieces along the interior of the sills on my XK-R please?
I have tried everything in my cleaning armoury but nothing seems to shift them.
Being plastic they are textured so I don't want to get too aggressive with the scrubbing and end up with damaged plastic either.
There must be something that will clean the caramel plastic trim?
Thanks.
Old Jul 11, 2010 | 08:47 AM
Quiet1's Avatar
Graham,
I dealt with this same problem yesterday while cleaning my XJ8.
My solution was not very elegant and I'm sure there are many other products that may be more "appropriate" but this worked for me.
I took a small, clean piece of cotton terry cloth, moistened it with "Wheel and Tire" cleaning solution, scrubbed over the black scuff marks and, voila! Clean as is was when it left the showroom. (I actually used it to "scrub" some of the same black scuff marks from the fabric covered trim just behind the plastic trim piece and it worked beautifully on that too.) Hope this helps.
Regards, Quiet1
Old Jul 12, 2010 | 09:51 PM
Beast's Avatar
In Australia, we have a brand called Polyglaze. I've used their dash and trim care and a bit of elbow grease on various cars and successfully removed the scuffs without damaging the plastic/ vinyl. The website says the product contains silicone, so this could be one of the reasons why it was able to remove the scuffs. It wasn't easy, but it worked!
http://www.polyglaze.com.au/products...trim_care.html
Basically, look for an interior detailer that's very soapy and slippery.
Old Jul 25, 2010 | 10:15 AM
dmdmkm2000stype's Avatar
try a magic eraser these things work on just about everything
Old Oct 23, 2010 | 08:10 AM
WldCat's Avatar
Glad I found this I'm very frustrated by the black marks showing up. I'm almost ready to cover the sill plates with clear shipping tape to protect the plastic sills from getting scratched/cut! Will try tire cleaner, Goo Gone and engine degreaser/cleaner this morning and see what works best.
UPDATE: The winner is Goo Gone, a paper towel and an old toothbrush. It even took off a bit of red nail polish I got on the boot lid (oops). Plus, it's a bit oily, so I went ahead and laid down two layers of clear shipping tape over the most abused areas of the sill. The slightly oily surface will allow me to remove it easily depending on how well it works or doesn't work.
Old Oct 28, 2010 | 12:06 PM
jagman73's Avatar
Hi. You can try (very gently and carefully) wet "magic sponge", for example Scotch-Brite™ Easy Erasing Pad. Remember just to try it first in some "safe place" becouse it works like delicate sandpaper. I succeeded in this way to remove black stains from the doors.
Old Dec 3, 2010 | 10:32 AM
WldCat's Avatar
Update: I've had to replace the tape on my sill plates already. BF and service technician both tore them up, and I could see black marks all over the tape. Well, better the tape than the plates! I think I'll stick with this method for the near future.
The caramel steering wheel -- now that has become a PITA to keep clean too. I use saddle soap but it leaves the wheel a little tacky and I'm concerned that I'll wear the leather out prematurely. (Amazing how quickly it gets dirty and how well dirt shows up on it!) I am seriously considering putting a (gasp) steering wheel cover over it. Anyone else do this? If so, what brand/style did you go with?
Old Dec 4, 2010 | 06:59 PM
TopHatChef's Avatar
I would never, ever use a steering wheel cover. I'd rather have a dirty steering wheel. I suppose you could do a few things, always wash your hands, and/or wear driving gloves.
Old Dec 8, 2010 | 10:36 AM
WldCat's Avatar
Wash my hands? Gee, why didn't I think of that?
Good grief.
Old Dec 21, 2010 | 01:33 PM
WldCat's Avatar
update: www.wheelskins.com
Beige/brown - beige is a little light, sand might be better match
Not perfect but when the time comes to resell, at least the OEM wheel will still look very good
Old Dec 22, 2010 | 12:47 PM
amcdonal86's Avatar
A lot of you guys probably put plastic covers on your sofas, too.
Old Dec 29, 2010 | 11:07 AM
WldCat's Avatar
Your point being ... what?
Old Dec 30, 2010 | 07:49 AM
Quiet1's Avatar
No. But I do leave the cellophane on the lamp shades.
42Ajd
Dec 30, 2015 09:45 AM
picard
Oct 12, 2015 11:56 AM
42Ajd
Sep 21, 2015 07:37 PM
Ipc838
Sep 13, 2015 03:27 PM
jaaag
Sep 11, 2015 12:53 AM
