Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
Removing glue off of inside rear window
Old 10-18-2014, 06:34 PM
jphurlman's Avatar
Default Removing glue off of inside rear window
I recently bought a 2004 XJ8 and the previous owner removed a decal or sticker from the inside rear window, about 4 inches square, leaving the glue residue on about 4 of the defroster elements (lines). How do I remove the residue without damaging the elements.
Old 10-20-2014, 03:56 AM
GGG is online now
Received 16,800 Likes on 12,169 Posts
The heating element is first screen printed onto the glass and then fired on during the annealing process so it's fairly robust. (I used to run a plant manufacturing auto glass many years ago).
Your wife's nail varnish remover on a soft cloth should clean any adhesive residue off.
jphurlman (10-20-2014)
Old 10-20-2014, 02:20 PM
jphurlman's Avatar
I have an adhesive remover pad with the following ingredients, will the small amount of silica be an issue? Thank you very much for your response.
Prep-Pad saturated with 70%
isopropyl alcohol and 0.01% precipitated silica
Old 10-20-2014, 03:26 PM
GGG is online now
The 0.01% precipated silica content will be present as a very mild abrasive. Allow the solvent to do the work without rubbing too hard.
jphurlman (10-27-2014)
Old 10-21-2014, 07:34 AM
jphurlman's Avatar
Smile Response to help
Triple"G"
Thanks again for your help and I will tread lightly and wipe off gently often with a mf towel.
Jim H
99xk8guy
06-05-2023 06:28 AM
RaceDiagnostics
09-07-2015 07:28 AM
davidladewig
09-03-2015 06:32 PM
Joey T
09-03-2015 05:31 PM
innzane
09-02-2015 10:08 AM
Quick Reply: Removing glue off of inside rear window
