Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
Sponsored by: CARiD
Removing glue off of inside rear window
Old Oct 18, 2014 | 06:34 PM
jphurlman's Avatar
Default Removing glue off of inside rear window
I recently bought a 2004 XJ8 and the previous owner removed a decal or sticker from the inside rear window, about 4 inches square, leaving the glue residue on about 4 of the defroster elements (lines). How do I remove the residue without damaging the elements.
Old Oct 20, 2014 | 03:56 AM
The heating element is first screen printed onto the glass and then fired on during the annealing process so it's fairly robust. (I used to run a plant manufacturing auto glass many years ago).
Your wife's nail varnish remover on a soft cloth should clean any adhesive residue off.
Old Oct 20, 2014 | 02:20 PM
jphurlman's Avatar
I have an adhesive remover pad with the following ingredients, will the small amount of silica be an issue? Thank you very much for your response.
Prep-Pad saturated with 70%
isopropyl alcohol and 0.01% precipitated silica
Old Oct 20, 2014 | 03:26 PM
The 0.01% precipated silica content will be present as a very mild abrasive. Allow the solvent to do the work without rubbing too hard.
Old Oct 21, 2014 | 07:34 AM
jphurlman's Avatar
Smile Response to help
Triple"G"
Thanks again for your help and I will tread lightly and wipe off gently often with a mf towel.
Jim H
99xk8guy
Sep 29, 2025 10:51 PM
RaceDiagnostics
Sep 7, 2015 07:28 AM
davidladewig
Sep 3, 2015 06:32 PM
Joey T
Sep 3, 2015 05:31 PM
innzane
Sep 2, 2015 10:08 AM
