Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
4.0 SC compression test.
Old Jul 11, 2013 | 01:39 PM
avt007's Avatar
Default 4.0 SC compression test.
Bear with me, I've never owned a supercharged engine. Before pulling the engine I tested the compression using my Snap On tester, and got all at 100 psi after 3 cranks except for the one bad cylinder at 125 (I assume the water was sealing the rings better) and one cylinder at 90 PSI.
Are these acceptable numbers? I haven't found them in JTIS, so I'm not sure.
Here's a video of the poor cylinder test.
http://s336.photobucket.com/user/avt...0a1f8.mp4.html
Old Apr 14, 2014 | 04:43 PM
rrosscoe's Avatar
Default Comp Test SC
Hi,
Just seen thread, I had problem with holed piston (NO8) so no reading on that one but had 120-125 on all others (at least if i remember correctly and yes i have Nikasil bores)
As it turned out the piston was holed between top and second ring but good old Nikasil there was NO damage to the bore so 1 new piston and alls good.
regards
rrosscoe
Last edited by rrosscoe; Apr 14, 2014 at 05:02 PM. Reason: couldnt spell nikasil properly!
aode06
Jul 28, 2023 02:26 PM
PhilXJ6
Jan 3, 2016 08:55 PM
pnwrs2000
Nov 17, 2015 04:04 AM
mat32essex
Oct 3, 2015 04:12 PM
