AJ27 oil pressure switch thread size and auxillary locations
Looking for specific information on the following two points:
1. thread size for the oil pressure switch on the AJ27
2. possible tapping points for an auxillary oil pressure sender
#2 is simply to avoid having to tee into the stock position. Teeing is not really a good thing anyways because it has the potential to snap off all the fittings due to the weight of the additional heavier sender.
The oil cooler lines are probably not a good alternative because of the temperature variant diversion.
