Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
Dyno advice?
Old Jun 19, 2012 | 07:29 PM
WaterDragon's Avatar
Default Dyno advice?
Hello all,
I am going in tomorrow to get a baseline dyno on my 2002 XJR to use as my "before" figures.
The plan was to run 3 pulls to get a more credible reading.
Any advice on how to dyno would be appreciated.
dyno in 4rth gear? How do I keep it from downshifting?
Old Jul 3, 2012 | 10:17 PM
MaSTi's Avatar
As long as you use the same dyno pre and post mods it should be fine. Best gear is closest for a 1:1 ratio. 90% of cars use 4th gear. I've always been a fan of mustang dynos as they can mimic a real world situation since they can apply load to the car, but when comparing numbers as long as you run the same dyno it's irrelevant.
Old Jul 3, 2012 | 11:44 PM
XJR-0220's Avatar
^^^^^ this pretty much says it all
Old Jul 3, 2012 | 11:57 PM
So you are both in agreement that regardless of the baseline running 50hp high, the changes from that baseline from mods B->C -> D should be reliable?
Just double checking to make sure I understand you correctly.
Old Jul 4, 2012 | 01:22 AM
XJR-0220's Avatar
as long as everyting is kept the same thts what I think anyway
Old Jul 4, 2012 | 06:01 AM
MaSTi's Avatar
exactly. just make sure your tuner applies the EXACT settings as before and you should see what you attained through your mods.
mikiep
Dec 20, 2019 07:37 PM
workworkwork
Oct 23, 2015 10:26 AM
adam699
Oct 13, 2015 05:53 PM
mbam504
Sep 29, 2015 04:56 PM
