Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
How to disconnect fuel rail inlet hose-'07 XK
Old Nov 16, 2012 | 10:19 AM
Rey's Avatar
Rey
Default How to disconnect fuel rail inlet hose-'07 XK
I want to disconnect the fuel hose from the fuel "rail assembly" at the left side of the motor. There appears to be a quick-disconnect/connect fitting that is safety-guarded by a simple black metal bracket. The fitting looks similar to that of GM products. I tried to disconnect. The car had been sitting for several weeks, so I assumed there was no fuel pressure in the line forcing the connection tighter. I have the little GM plastic tool for this, but it doesn't fit and is useless. Additionally, the connection seemed really tight and could not rotate the connection.
Question: is there a special Jag tool required; and if so, what is the part number/cost/etc. Alternatively, am I just missing something in the procedure.
Old Nov 16, 2012 | 11:22 AM
Fuel line Spring Lock Couplings:
JAGUAR X150 - Spring Lock Couplings.pdf
Is this the type of coupling you need to release?
Old Nov 16, 2012 | 04:41 PM
Rey's Avatar
Rey
Graham, it is the coupling. Many thanks.
Rey
Old Nov 16, 2012 | 06:14 PM
Rey
Rey,
Pleased to hear it's the right one. It certainly looks an unnecessarily complicated coupling but must make for a quick assembly job in the factory.
I have a bit of self interest in getting to know the XK/XKR as it will probably be my next Jaguar model.
Old Oct 18, 2021 | 11:30 AM
Vinsanity's Avatar
Attachment 26156
This also answers my question with my 05 XJ8.
JWheeler
Nov 22, 2019 08:28 AM
ogorir
Jan 18, 2016 10:09 PM
Papelione
Sep 21, 2015 06:13 PM
TheWarlock
Sep 20, 2015 03:22 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
