Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
intercooler auxiliary water pump
Old Aug 14, 2010 | 03:39 PM
sivkov-y's Avatar
Default intercooler auxiliary water pump
Hi to everyone, i would like to know if anyone here knows the specs for the intercooler water pump that is installed on the STR's (flow rates,pressure,etc...) Mine has a cracked housing where the impeller is located. I think i may have found an aftermarket substitute, but need the specs for a similar match in performance. Here's a website, on the page look at the bottom three pumps.
http://www.ittflowcontrol.com/marine...ulation-pumps/
Old Aug 15, 2010 | 04:34 AM
Panthro's Avatar
Check this thread, particularly post #41. Hope that helps.
Old Aug 18, 2010 | 04:24 PM
Staatsof's Avatar
I've used the ITT bilge style pumps with a flex-vane impeller on another car for about 25 years. I replaced it once though there are impeller repair kits. But these aren't really meant to be run full time which is the case in the STR. I've already located a magnetic drive pump (no shaft seals) for the next replacement on that other car but I don't know the specs required on the STR to know if it would be suitable. I sure like the idea.
It might be worth an investigative look?
here's one http://www.ittflowcontrol.com/marine...-item12789.htm
A max of 185F for the collant.
Is this a real issue?
Does the pump suck from the bottom of the heat exchanger or push through the top?
Here are the specs on the commonly utilized Bosch replacement pump
http://www.boschmotorsandcontrols.co...2002/index.htm
There aren't any temp ratings from Bosch and I don't know how to covert their flow specs for a comparison.
Examples of application:
Application
Please contact us if the pumps
are to be used for fluids other
than water.
Type
Centrifugal pumps with mag-netic
coupling, no seal between motor and pump, therefore leak-free.
Note!
These water-circulating
pumps are not self-priming.
Application
than water.
Type
Note!
So these are magetic drive as well!
Bob S.
Old Aug 22, 2010 | 09:45 PM
sivkov-y's Avatar
Thank you very much for providing this info, very helpful. Thanks.
Old Feb 24, 2011 | 02:33 AM
plums's Avatar
The big deal in Mercedes C32 circles is that the pump equivalent, except for the valve end is a Ford Lightning pump. They save big money by undoing two philips head screws and swapping the valve end. Both are Bosch sourced.
Lasts a long time in the Ford application, dies fast on the Mercedes.
The difference is Ford mounted it vertically, and Mercedes mounted it horizontally. The brushes wear out in that orientation.
Johnson pumps are a popular upgrade.
Wahooesprit
Dec 23, 2019 02:01 PM
Ozzy_UK
45
Feb 19, 2019 02:05 PM
Ozzy_UK
General Tech Help
Jan 14, 2016 02:52 PM
ksjaguar
Nov 3, 2015 10:14 AM
picard
Oct 12, 2015 11:56 AM
