Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
Looking for engine help in Tampa, Florida Ftype V8 S
Old Feb 12, 2020 | 12:26 AM
Hunter Mc's Avatar
Default Looking for engine help in Tampa, Florida Ftype V8 S
Looking for any help in locating a engine or rebuilding my engine or installing a engine. Desperate at this point.
Old Feb 12, 2020 | 12:44 AM
jackra_1's Avatar
You need to provide a few more details about your car.
Such as year and engine type/size. Also what is wrong with it.
Old Feb 12, 2020 | 10:59 PM
Hunter Mc's Avatar
Says those things in the heading but here it goes. First time in any forum.
2014 Jaguar F-type V8-S / V8 5.0 / 8th ending in L Jaguar dealership says I need a new engine. They say catastrophic engine failure due to overheating. Cylinder 6 piston is scored. First issue was the inlet pipe cracking... Jaguar acknowledged that this is a known issue as they have redesigned the part but do not take any ownership that that part caused the catastrophic engine damage. I am looking for help maybe options or some guidance.
Old Feb 13, 2020 | 07:44 AM
jackra_1's Avatar
There are several threads on the 5.0 engine where it needs to be replaced/rebuilt. Unfortunately this engine commands a premium even used.
A dealer will charge you a fortune.
I am a DIYer so if it were me I would take off the cylinder heads to determine the amount of damage and go from there.
I am wondering how a piston was scored? If a valve hit it then yes there is catastrophic damage.
I would guess that minimal damage would be slightly warped heads and one scored piston and a damaged valve at a wild guess.
At least you did not have the famed timing chain failure.
RIRR
Jun 3, 2021 02:34 PM
Queen and Country
Oct 4, 2019 03:10 PM
Jagst
May 18, 2015 09:17 AM
racerxf12004
Aug 5, 2013 09:16 PM
