Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
Oil Pump Questions for 5.3L V12 in 1985 XJS
Old Oct 6, 2014 | 09:01 AM
Safari's Avatar
Default Oil Pump Questions for 5.3L V12 in 1985 XJS
Engine: 5.3L V12
Car: 1985 XJS
If the engine is out of the car how can I test the oil pump to insure it is good?
Can it be rebuilt? If so, what company has a rebuild kit?
If I want to replace the pump which company offers the best price?
What other parts should be replaced when the pump is out?
Can the pump be driven to produce pressure before the engine is started?
Thanks!
Old Oct 11, 2014 | 11:21 AM
ronbros's Avatar
just about NO on all questions! sorry.
take it apart,clean it up ,and examine every detail for wear or scoring.
Old Oct 11, 2014 | 01:38 PM
blackhonor9's Avatar
To piggy back off of Safari, how can I determine if the oil pump is working properly. I'm getting code P1384. I changed the vvt solenoid, the camshaft, the bracket that attaches to the camshaft. The only other issue that could cause this code is low oil flow to the right vvt solenoid.
Thanks.
Old Oct 12, 2014 | 03:24 PM
xjr5006's Avatar
given that new ones are now over £500 + you will need the later type of crank drive (total £600+ ) I wouldnt even bother to check. It will work fine even if has a score mark or 2.
toronadomike
Jan 22, 2026 10:13 PM
Russ Graber
Feb 23, 2019 11:59 AM
DrScientist
Dec 9, 2015 07:36 PM
alpecsa
Sep 7, 2015 11:55 AM
