Mark V - X 420G 1948 - 1970
1966 Mark X starter wiring question
Old Jun 12, 2020 | 01:26 PM
karlheinzr's Avatar
Default 1966 Mark X starter wiring question
Hi everyone,
I just bought a new project car - a 1966 Mark X with the 4.2L equipped with triple SUs. The previous owner already did a decent paint job and wanted to do the interior which is already partly teared down but didn't finish what he planned to do because of the lack of time.
The engine has fresh oil and coolant as well as good spark plugs.
I wanted to start it but the ignition switch as well as the start button are disconnected and for this moment I didn't want to mess with the wiring.
Instead I wanted to start it by giving power to the starter solenoid to make the starter turn over and power to the coil to make the spark plugs fire. I would also hook up an electric fuel pump that would pump fuel from an external tank.
I used to do that once on a friend's Volvo 122.
It will sound stupid but when I looked at the Mark X starter I was a bit confused because I've never seen such a wiring at a starter in cars that I've worked on. I googled for wiring diagrams but unfortunately I didn't find any for this one. In cars that I've worked on you would have 2 thick wires going to one stud and a thin one going to a different, smaller one that gives power from the ignition switch.
In attachement you'll find a photo of my starter with all the wires numbered and the very upper connection marked with a circle that I think might be the one I should give 12V to.
I am asking though since I'm not 100% sure about that.
I would also really appreciate if you could tell me which wire at the starter is for what but the main thing is where should I give power to.
I'm looking forward to your answers.
Thank you in advance.
Old Jun 13, 2020 | 06:37 AM
pendliss's Avatar
I have attached a copy of the wiring diagram for your reference.
Phil E.
File Type: pdf
Old Jun 16, 2020 | 03:30 PM
karlheinzr's Avatar
Phil E.
Thank you very much for your reply and the diagram.
You really helped me with it.
Take care brother
Old Jul 2, 2020 | 02:53 AM
Phil E.
Phil,
That's a work of art.
JPG version here for anyone who doesn't have forum file download rights.
Old Feb 9, 2022 | 03:52 PM
MustangSally5's Avatar
Did you have any success getting the car to fire or turn over?
Have a 420G in storage and thinking of doing the same thing.
tilbury
Dec 2, 2016 07:33 PM
cooolblu
Aug 10, 2014 08:55 AM
superchargedtr6
Jul 12, 2014 09:24 PM
maikal_0011
Nov 5, 2011 11:18 AM
xjrwithproblems
Aug 6, 2010 07:04 PM
