Need help removing front seats on a Mark X
I've recently acquired a 1966 Mark X and am in the process of stripping it down before the body work can be done. Has anyone got the secret of how to remove the screw holding the rear of the front seat frame from the floor mount? Even after moving the chair all the way forward exposing the screw, there seems to be no way to actually access the screw as there is no space for a screwdriver. Is it necessary to take the entire frame apart first?
Actually, thinking about it, you might need to take off the two trim pieces at the rear corners.
