Jaguar Alcon 400mm front rotors new
For SaleBrakes
Description:
Jaguar Alcon 400mm front rotors brand new, never fitted, left and right handed with directional vanes. $100 for the pair + shipping
Hello, I’d certainly be willing to. The issue however’s the cost. Weight’s about 72 pounds and transport for the US was significant. Be prepared to spend several times the cost of the discs. I’d need your full address to provide a quote.
Thank you - if you could look at shipping to Russley Road, Christchurch, New Zealand 8042 that would be appreciated, although by the sound of it it may be slightly terrifying!! You don’t have rear rotors as well do you - 350mm?
Are these OEM or remakes? Do you have left and right?
Are the crescents drilled all the way through?
Thanks!
Thanks!
Yes, the description states for both left and right. These are grooved as pictured and specified by Jaguar, they aren't drilled and they are aftermarket from Centric, not sourced from Jaguar directly. Hope that helps.
Still available and to confirm these ONLY suit Alcon fitted cars. Also I’ve no control over transport costs, I’ve got these marked down to below cost and it’s still an excellent offer as it is for 2 brand new front right and front left as a set.
