Selena 20" for 09 XKR Portfolio
WantedWheels and Tires/Axles
Description:
Looking for a set of Selena 20" for Jaguar XKR Portfolio. These are very specific wheels that came with the car. Thanks!
Thomas call or text me at 8O8 772-O790
Yes, they are Selena wheels but ...
Your Personal Profile says that you have a 2011 XF. Is it equipped with the E-diff? The OP has a 4.2L 2009 XKR Portfolio. Here's the problem:
20" Selena wheels were available to fit the XF, but I'm pretty sure that the rear offset isn't the same as on the 2009 XKR Portfolio, which doesn't have the E-diff. Also, they're not the same color. I'm also not sure if they're the same width; the XKR has staggered fitment, with 8-1/2" wide fronts and 9-1/2" wide rears.
The OP needs to make sure that the offset and width are the same as his OEM wheels. Color isn't important since you can have them refinished so they all match.
