VAP tuner kit with crank pulley & belt for V6 S.
For SaleEngine - Power Adders
Description:
VAP Kit includes tuner, crank pulley & belt - all new - never installed on 2017 F-Type V6 S.
Kit new is $2600 - sell for $2000 CDN + shipping.
The correct replacement pulley and belt depend on the colour of your OEM pulley, silver or black.
As far as I can figure out the OEM pulley changed from silver to black with the MY 2016, ie MY 2014 and 2015 have the silver pulley then from 2016 onwards they have the black pulley.
No good looking at the new/larger pulley as they are all black anyway.
You can juuust see the pulley from the top if you shine a torch down on it and look reeeeeel hard, but it takes better eyesight than mine.
Much easier to see from underneath but that means you have to remove 4,637 bolts to get the undertray off.
You are correct- my 2017 S had the black crank pulley. You should be able to see it from above with a flash light. That’s how I check to see mine when I ordered from Stuart at VAP.
ok cool maybe @Stuart@VelocityAP can confirm whether the setup will work for my car and is transferrable, I'll shoot him a DM and get back to you.
Edit:
Seems like he's exceeded his DM storage limit. I'll try to reach out another way.
Edit:
awesome thank you
I reached out to @Stuart@VelocityAP and he said it would be transferrable assuming you hadn't used the tuner before. And that the pulley would depend on which pulley our cars started out with (the black one for both, it seems), and a VIN lookup to make sure the belts would be the same.
If you could DM me your VIN so I can reach back out for that confirmation that'd be great.
