XK8 Convertible, A Grand Touring Automobile For The Mountains of Colorado
For Sale
2001 Jaguar XK8
  • 2001 Jaguar XK8 - XK8 Convertible, A Grand Touring Automobile For The Mountains of Colorado - Used - VIN SAJDA42C01NA14633 - 64,064 Miles - 8 cyl - 2WD - Automatic - Convertible - Other - Littleton, CO 80123, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
  • Price
    $3,500
  • Location Littleton, CO, 80123, USA
  • Condition Used
  • VIN SAJDA42C01NA14633
  • Mileage 64,064
  • Engine 8 cyl
  • Drive Type 2WD
  • Transmission Automatic
  • Vehicle Type Convertible
  • Exterior Color Other
Description:
NOTE:Currently there are known issues with timing chain, guides and the plastic tensioners, bearings in motor requiring repair.
Vehicle may be viewed & inspected at Genuine Auto Repair Littleton CO 80123. Genuine's master mechanic diagnosed motor issues. Genuine Auto is willing to detail needed motor repairs. 720-799-8501
History
Purchased new from San Jose British Motors as a company vehicle for the original owner, sold to the second owner in 2015. Second owner donated the automobile via BringATrailer.com auction website on Behalf of Humane Society Daly City CA.
Current owner purchased (Bring A Trailer) the XK8 convertible 7/25/17, shipping via enclosed car hauler from selling agent California address to Denver Colorado.
Description
Power is from a naturally aspirated 4.0-liter DOHC V8 that was rated at 290 horsepower when new and is paired with a ZF 5-speed automatic transmission. The deep green metallic paint bears occasional signs of use, including a smattering of rock chips in the nose and the finish on the trunk lid shows patchy fading in direct sunlight as detailed in the gallery. Factory split-spoke wheels show some curb damage and wear. The fabric convertible top is in excellent condition (garage parking only), and it functions satisfactory, with no know hydraulic issues, said top houses a heated glass rear window which is functional. Finished in creme leather set off by glossy burl walnut trim (rare), the interior shows mild creasing along with a small wear spot on the outer driver's seat bolster. Front seats are heated and powered on both sides. A crack is noted in the plastic driver-side kick panel. Factory carpet floor mats remain in place, with new WeatherTech mats protecting original carpeting. A stock stereo is retained along with a trunk-mounted CD changer and separate factory DVD-based navigation system. The digital odometer currently 66064 miles.
Tires
New Continental Speed-Rated
Carfax
Report (08-01-19) shows dealer maintenance from new and details a minor rear-end collision in 2009, with the report noting the rear end incident and specifies no airbag deployment.
Service & Repair
Regular oil changes are noted on the Carfax report along with replacement of the fuel pump and filter in 2014. Earlier services included replacement of brake lines in 2010 at 46k miles. Immediately after purchase, current owner replaced alternator at Aspen Auto, plus: thermostat housing/gasket replaced, oil pan gasket replaced, thermostat replaced, crankshaft oil seal(s) replaced, timing chain tensioner/guide replaced, oil (synthetic) and filter changed, valve cover gasket(s) replaced, drain plug gasket replaced, cooling system serviced, crankshaft pulley/balancer replaced, and engine timing/front cover gasket replaced.
The seller has driven the car 1264 miles since purchase (07/25/17) near mountain home in the Colorado with minimal city miles (for delivery and service only). This is a delightful touring automobile with ample power and agility for the curves of country roads or overtaking on mountain passes, especially with the convertible top down.
Old Nov 7, 2019 | 04:15 PM
stuizzy's Avatar
Are timing chains just noisy or has something broken and damaged the engine?
Old Nov 11, 2019 | 10:06 AM
XJsc-guy's Avatar
Default Sent PM for more info.....
Sent you a PM with questions on engine or other issues....
Old Nov 12, 2019 | 02:52 PM
RockyMtnXK8's Avatar
Timing chains guides were replaced prior to latest issue, they probably need replacement. There is damage to the engine, mechanic recommends rebuilding this motor or buying rebuilt as replacement. It is a project motor regardless how you proceed.
Thank you for your question and interest
Lori
Old Nov 12, 2019 | 02:53 PM
Motor is damaged, either rebuild this motor or buy rebuilt to have running XK8
Old Nov 12, 2019 | 02:55 PM
I am somewhat new to the forum, I may have missed your PM. If you have not received an answer, please resend your request
Thank You Lori
Old Dec 2, 2019 | 09:25 PM
Cat Lover's Avatar
Default Thanks Lori!
I'll give this Cat a good home. It has at least one more life left in it. I wouldn't mind getting my hands on any documentation or paperwork you may have. Please send it to Heather, if it's not too much trouble.
Thanks again
Greg
Old Dec 2, 2019 | 09:26 PM
Cat Lover's Avatar
Thanks again
Greg
