XKR / XK parts new and use spares
For SaleMiscellaneous
Description:
I have several parts available purchased as spares and leftovers for my 2001 XKR:
some will fit XK8, make sure it will work for your application.
transmission W5A-580 under 60k miles very good
Alternator, needs rebuild
taillights, left side new right side OK used
Windshield trim
rear 1/4 light trim both sides (coupe)
exhaust, from x-over muffler back, VG (I installed a stainless system from XKs)
occupancy sensor set, new (from convertible but the elements are all the same)
steering rack seal rebuild kit new (I only used the shaft column seals, the used ones are included as they are easily matched and obtained)
NAV dash wood set, needs re-doing.
Gas cap (replaced twice, was never the problem)
Relays
I will list more as i find it!
Make a reasonable offer, located in Oviedo, Florida.
do you have the navigation DVD? Also the relays would be great too as spares.
You will have to arrange pick-up, there are services like youship that should be able to do this cheaply.
Windshield trim
Relays
I'm also interested in the differential itself, as well, if that's available.
I'm in St Louis, MO if the freight isn't exorbitantly expensive, otherwise I might be able to make a trip there.
Thanks!
