Mexico, South America All non-US residents of North, Central, and South America
Jaguar XJ6 (XJ40) 1988 AUTOMATICO
Old Sep 21, 2016 | 09:09 AM
patotortora's Avatar
Default Jaguar XJ6 (XJ40) 1988 AUTOMATICO
Hola soy de argentina y tengo un jaguar xj6 (xj40) 1988 automatico
la caja de transmision esta rota y estoy buscando ayuda para comprar una nueva/usada y traerla a la argentina.
Gracias!
Old Apr 10, 2018 | 06:33 PM
Hola Patricio,
(Please use English on the forum)
You posted about needing a transmission in September 2016.
https://www.jaguarforums.com/forum/x...omatic-169679/
Are you unable to find a replacement or a repairer in Argentina?
Old Apr 11, 2018 | 08:27 AM
Hi Graham,
Yes, do you have any suggestion/idea?
Old Apr 11, 2018 | 09:44 AM
Are you certain you need a replacement transmission? What is the fault?
If you definitely do need a replacement:
Option 1 - rebuild your transmission
A rebuild is the lowest cost option and the transmission would be "as new". A Google search returns several automatic transmission specialists in Buenos Aires. It does not have to be a Jaguar specialist. Automatic transmission specialists can rebuilt any type.
Option 2 - locate a used transmission in BA or within Argentina
In his reply to your other post, Don B wrote that if your car has a 3.6 litre engine, the transmission is probably the ZF 4HP22, which was used not only in the Jaguar XJ40s, but in several models from BMW, Land Rover, Peugeot, Volvo, and others, including the Chevrolet Opala that was sold in South America. This should increase your chances of finding a good used transmission in the Buenos Aires area.
Option 3 - import a used/rebuilt transmission
Distance will be the problem. UK or USA are sources; Australia is another but nearly twice the distance from BA.
Old Apr 11, 2018 | 10:16 AM
Thanks Graham !
Appreciate your reply.
alserry
Mar 6, 2017 12:41 PM
patotortora
XJ40 ( XJ81 )
Sep 25, 2016 08:26 PM
patotortora
Sep 21, 2016 05:34 AM
patotortora
Sep 20, 2016 01:30 PM
Jaguar Forums Editor
Jaguar Press release
Sep 20, 2016 10:58 AM
