1963 mk2 front brakes
Old Nov 7, 2021 | 12:43 PM
Dwl's Avatar
Dwl
Default 1963 mk2 front brakes
i got my mk2 as a apart project, it came with 4 rebuilt brake cylinders. 2 have sq. pads but 2 have round pads. the numbers on the round pad units don't match anything in the parts book. i can't ell if they are front or back . i don't even know if they will fit the mounting plates that are also in the box..i have seen that there a shims to put mk2 on a mk1 . but has anyone tried puting the mk1s on a 1963 mks. maybe i should get rid of them and just get rebuilt mk2s. any help is well appreciated.
Old Nov 7, 2021 | 01:51 PM
Peter3442's Avatar
I believe a 1963 MK2, in fact all Mk2s and late Mk1s, should have square pads on all wheels. Round pads were fitted on some MK1 cars. Is it possible your car has some MK1 parts? The round pads are more difficult to change.
If the pads and calipers are wrong, it would be a good idea to check other parts: uprights, wishbones, rear axle
Old Nov 7, 2021 | 05:21 PM
Fraser Mitchell's Avatar
YOu should not have round pads on your Mark 2, and it is a puzzle where they came from in your pile of bits, but a Mark 1 is more likely, and the owner just didn't have the knowledge to know they were not correct. The later, square pad calipers were brought in to make brake pad replacement much quicker and easier. What I'm not sure about is whether the later square pads require a different caliper to that used for the round pad type. It they're the same, it's just a matter of buying a couple of square pad piston assemblies. Of course, you could consider just replacing the lot with modern low maintenance calipers made for fitting to Mark 2s.
Edit
A quick look on the SNG Barratt website shows the two types have no compatibility. Best to find a pair of the later calipers and piston assemblies, as tey are freely available.
Old Nov 9, 2021 | 12:08 PM
Dwl's Avatar
Dwl
looks like all of the front end has never been touchec. all of the mounting holes for the mounting plates and calipers line up. so i guess i'LL try tem but if i get into trouble let me know if anyone need MK1 rebuilt cylinders. i'll get some real MK2's. if anyone is interested i pulleht old orig. radiator still good,but had a new rebuilt one in the trunk... boot... also i pulled the complete ac unit originalall complete and operational thanks for the advice dwight.
Old Nov 9, 2021 | 12:14 PM
Dwl's Avatar
Dwl
Thanks , but on a loose test fit they seam to be workable. maybe different sins or wasers.. but if someone needs the MK1's let me know , or if someone has a good used set of MK2's i'd take them. i Also need the complete set of hade brake calipers they were not in the boxes. i have a original radiator ,good, and a complete ac system. avalible thanks dwight
MussieRon
19
Aug 26, 2023 11:04 PM
Butty
UK & Eire
Feb 22, 2018 09:21 AM
ViolentBlue
Canada
May 8, 2014 12:40 PM
Aron Gundry
Nov 3, 2013 07:39 AM
