1967 Jaguar MK2 3.4
Old Sep 17, 2021 | 08:02 AM
paddyx350's Avatar
Originally Posted by JeffR1
It's been a while, but from memory, I took the locking plate off.
And I don't think there is a enough room to get a ratchet in there, so I used a breaker bar.
The breaker bar is shallow enough with a socket.
The socket is put in place first and then the bar is inserted into the socket.
I think there is enough room just to get the socket off and on to rotate the engine once the tool is in place.
I have done it to time the ignition _ I know I have, and I certainly would have remembered if had to take the rad out.
I did from down below on my side with the car jacked up a bit.
I believe that the engine should only be rotated manually in a clockwise direction.. others please correct me if I'm wrong
Old Sep 17, 2021 | 08:34 AM
Peter3442's Avatar
It's not a good practice to turn any engine in the direction it doesn't normally run (mainly to protect valve gear tensioners and possibly the transmission). Due to clockwise depending on which direction you are facing, I'll say turn it so the exhaust side of the crank is going down and carb side up. That said, a few degrees in the wrong direction shouldn't harm an XK.
Old Sep 17, 2021 | 12:23 PM
JeffR1's Avatar
What Peter said, but some engines it doesn't matter, especially non-interference engines.
Generally engines with timing chains that use hydraulic tensioners should not be rotated counter-clock-wise.
Standing at the front of the car looking at the front wind screen, the engine will be running clock-wise.
Gear driven cam shafts and cam shafts driven with timing chains with no tensioners _ it really wouldn't matter.
Old Sep 17, 2021 | 01:35 PM
David84XJ6's Avatar
Quote "Really difficult. On other cars you can get a socket on the front pulley nut, remove the spark plugs and rotate the engine using a ratchet on the socket. With the Jaguar and I can only speak of my S Type there is just no room between the engine and the back of the radiator to get anything in there." unquote
This works on XJ6: see attached
Rgds
David
File Type: docx
Old Sep 17, 2021 | 04:20 PM
Cass3958's Avatar
Nice tool and well thought out but it would still not work on the S type. The S type has a shroud around the fan which stops you getting anything on the bottom pulley nut. You could I suppose bend the shroud to one side but it is made of a fibreglass material and I would be afraid of breaking it.
MussieRon
19
Aug 26, 2023 11:04 PM
rdssdi
Jul 22, 2015 09:21 AM
ViolentBlue
Canada
May 8, 2014 12:40 PM
Aron Gundry
Nov 3, 2013 07:39 AM
