240 engines - various compression rates?
Old Nov 19, 2018 | 07:01 AM
Lambretta's Avatar
Default 240 engines - various compression rates?
Hi all
On the engine numbers I read: "Note: Suffix of /7 or /8 to the engine number denotes compression ratio."
So, all the 240s came with an "8" compression rate on their engines or there have been also some cars with "7"?
What's the difference in practice between 7 and 8?
Cheers,
Nassos
Old Nov 19, 2018 | 07:20 AM
Glyn M Ruck's Avatar
It's all in the pistons on a Jag & fuel availability in different markets. The higher the compression ratio the higher the performance but also the higher the propensity for knock, pre ignition, detonation, pinging by whatever term you know it. Jaguar built 7 to 1 CR engines for poor fuel markets where only low octane fuel was available. 8 to 1 CR was the most common. They built engines with all 3 compression ratios.
jawdoc
Dec 7, 2012 12:07 PM
FrenchJagman
Oct 19, 2011 04:00 AM
Big Worm
Nov 20, 2009 11:12 AM
