3.8 Engine rebuild
Old Aug 18, 2024 | 03:45 AM
  #261
Peter3442's Avatar
Yes, quite a lot of oil mist escapes via breathers in all engines, which is one of the reasons that designs with catch cans have an attraction but may be difficult to make work. The plenum in the series 3 fuel injection intake is a low point in the intake and easily collects half a pint of oil. Fortunately, it doesn't upset the engine running too much.
Old Aug 18, 2024 | 08:08 AM
  #262
jayd2's Avatar
This was the original filter location. The air flow at was definitely pressurizing the crank case. All of the engines I've owned had a vacuum line attached to the intake with an inline check valve.
Old Aug 18, 2024 | 08:19 AM
  #263
jayd2's Avatar
Originally Posted by David84XJ6
A flexible breather line will let you vent engine to atmosphere, closer to the ground below your motor. You will get a messy oil film all over the side of the engine with your current configuration.
https://mossmotors.com/jes-8234-cylinder-head-breather
Rgds
David
I had a piece of scrap copper tubing and it allowed for a quick fix to see if crank case pressure was causing the rear main to leak. There is a long list of issues I still need to address to refine the installation of the Jaguar engine.
Old Aug 18, 2024 | 08:39 AM
  #264
Peter3442's Avatar
Apart from any effect of the air flow, you definitely don't want the filter. Flow from the breather is out from the crankcase. The filter serves only to block increase pressure in the crankcase as it oils up.
If you're not going to a more sophisticated system with a PCV (one way valves, catch can, etc), the ideal is to have the breather exit at or a little below atmospheric. Then, there's no pressure pushing oil out through crankshaft seals and the like, and not too much flow through the breather carrying out oil mist.
Old Aug 18, 2024 | 09:07 AM
  #265
jayd2's Avatar
A vacuum based PCV might not a good idea, the rear main has no seal. Creating a vacuum could cause air flow to enter the rear main scroll, possibly allowing contaminates to enter the engine.
Old Aug 18, 2024 | 11:43 AM
  #266
hueyhoolihan's Avatar
to do it right, it looks like i'll need to route it back to one of the two new air cleaners i've installed. i think a plastic tube and fixing hardware for the tube was provided with each air cleaner. a hose of proper ID and two hose clamps should do it. if stout enough the hose may not need support...could i be so lucky?
Old Aug 18, 2024 | 03:39 PM
  #267
David84XJ6's Avatar
Smile
Cut bottom of breather pipe at 45 deg. with long side forward, to create slight low pressure area at breather exit (I would not add the filter). With the exit below the engine you will have sufficient airflow. The length of the breather pipe is sufficiently long that you will have to trim it to fit.
Later "smog" cars vented breather to the back of the air cleaner(s) to burn blow-by fumes, unfortunately this introduced blow by oil into the intake system and made a mess in the carbs. I added a $25 eBay universal oil catch can before filters on my XKE. This is pure environmental, no benefit to engine or performance. I assume since you now understand it's a jaguar engine, you have the obligatory "oil drip pan" on you garage floor.
Old Aug 18, 2024 | 03:45 PM
  #268
Glyn M Ruck's Avatar
With a proper Plenum Chamber the oil drips out of the plenum chamber drains.
Old Aug 18, 2024 | 03:52 PM
  #269
With your vehicle you can do as you like.
Old Aug 21, 2024 | 02:45 PM
  #270
jayd2's Avatar
Default First Oil Change
I just completed the first oil change. The oil filter paper pleats inspection was good, it was very clean with minimal contaminates on the paper pleats. This engine has the downward facing oil filter, you must allow the oil to flow back into the pan to get an accurate level check. With 6 1/2 quarts the oil level is in the middle of the Full area.
Old Aug 21, 2024 | 02:52 PM
  #271
jayd2's Avatar
Default First Engine Rebuild - Completed
This was my first engine rebuild, it was worth the effort. The engine is running great and I got to experience the rebuild process.
The Moss 4 speed with overdrive was also an interesting project. It had to be disassembled, cleaned and inspected, then reassembled. There were some issues but they were easily resolved.
Old Aug 26, 2024 | 07:51 PM
  #272
jayd2's Avatar
Default Oil pressure after oil change
Oil pressure higher after engine break-in and first oil change. The break-in oil was 30w with no detergent, it now has Valvoline VR-1 10w-30 racing oil. During the break-in period, the oil pressure was 25 psi at idle and 40 psi at 2000 rpm. With the Valvoline VR-1 the oil pressure is now 30 psi at idle and 50 psi at 2000 rpm. Should the oil pressure be different with 10w-30 VR-1?
Old Aug 27, 2024 | 03:09 AM
  #273
It all depends where they blend within the viscosity range.
Old Aug 27, 2024 | 03:29 AM
  #274
Peter3442's Avatar
Does the oil pressure stop rising at engine speeds above 2000 rpm? If it remains about constant, the relief valve is working and everything is probably OK. The usual guide is to have anything over zero at idle and 40 psi at 3000 rpm. (And of course there are all the usual previously listed provisos about electrical and mechanical gauges).
Old Aug 27, 2024 | 06:21 AM
  #275
Yes , as Peter intimates the electrical oil pressure gauges are notoriously inaccurate.
Old Sep 1, 2024 | 04:47 PM
  #276
jayd2's Avatar
Default Laycock Overdrive - Engage/Disenage
The transmission, a Moss 4 Speed, has a Laycock overdrive. There is a mechanical lever and a solenoid on the overdrive that can engage or disengage the unit. How did the driver engage or disengage the overdrive? I haven't tested the solenoid. It looks like I could use the mechanical lever to operate the overdrive, is that possible?
Old Sep 1, 2024 | 05:22 PM
  #277
jayd2's Avatar
Default Moss 4 Speeds
I just purchased 2 Moss 4 speeds with Laycock overdrives and 1 bell housing. One Laycock has a cracked housing and both transmissions are locked up. It will be interesting to see if any of the internals are good.
Old Sep 2, 2024 | 02:49 AM
  #278
You cannot reverse these cars with the Overdrive engaged. That's why they have an inhibitor switch on top of the gearbox. If you do you will smash the rotary one way clutch & break the OD housing.
Old Sep 2, 2024 | 05:07 AM
  #279
Peter3442's Avatar
.... which is an extremely good reason for operating the overdrive electrically with the solenoid. Apart from that, it's really neat switching a gear in an old car by flicking a stalk on the column.
Old Sep 2, 2024 | 03:59 PM
  #280
jayd2's Avatar
I just purchased 2 Moss 4 speeds with overdrives and one has a cracked overdrive case. I wonder if the damage was caused by a reverse/overdrive incident?
There are 2 switches on the transmission, one is for reverse, what is the other one for?
