340 Power Steering
Old Aug 26, 2023 | 09:53 AM
oxendine's Avatar
Default 340 Power Steering
This seems like an simple question but I can't seem to get it right. After re fitting my power steering box and all I cannot get the reservoir hoses to quit leaking. Moss want $50 plus shipping for 2 hoses. I took the old ones and had some hyd hose cut to the correct length. No matter how tight I do the clamps the hoses still leak at the reservoir fittings.What's up?
Old Aug 26, 2023 | 10:17 AM
Cass3958's Avatar
I think we talked about this recently. Aren't there some olive joints that go up inside the reservoir fittings that the hose clamps up against.
The actual rubber hose it held on to the fitting by jubilee clamps but the metal fitting which screws into the base of the reservoir to which the rubber hose connects has several olive joints and seals as can be seen in the parts diagram below. Part numbers 6, 8 and 10.
I recall someone saying they were having difficulty finding the original part and had to fit a rubber washer seal from a multi kit.
Old Aug 27, 2023 | 10:27 AM
oxendine's Avatar
Thanks. When I removed the reservoir form the car one of the hose fittings wasn't threaded in fully? I have no idea of how that happened. I went ahead and found a couple of O rings that fit and now I have no leak.
Thanks again.
Old Sep 11, 2023 | 07:59 AM
oxendine's Avatar
So much for no leaks. My reservoir is leaking again. The O rings I fitted look to be the same diameter but don't look to be quite thick enough to seal the opening. I've removed it again and looking for suggestions?
Old Sep 11, 2023 | 02:46 PM
Cass3958's Avatar
Try putting two O rings in each connection. Might fill up the gap and the rubber of the two O rings will seal against themselves. Failing that I use this stuff to form gaskets and it might work in the connection rather than an O ring.
benji808
Jul 16, 2023 09:21 PM
olivermarks
XJ XJ12 ( X305 )
Apr 4, 2022 08:32 AM
Johnny_B
Jul 31, 2018 02:22 PM
YycXJS
Mar 12, 2015 10:16 PM
mrtalkradio
XJ40 ( XJ81 )
Nov 17, 2013 10:28 PM
