'65 S-Type Heater
Old Dec 5, 2012 | 03:37 PM
Don S-Type's Avatar
Default '65 S-Type Heater
Can you repair/rebuild the coolant control valve?
Old Dec 6, 2012 | 06:51 PM
Jose's Avatar
if you mean the original Heater Servo (valve), not yet, but I'm working on getting them rebuilt with a new diaphragm so don't throw it away!
in the meantime, you can go to CarQuest and order a Normally Closed / Open with Vacuum heater Valve part number CTC-277826 like the one in the picture below. It will do the job fine.
you'll need a hose splicer-reducer and a 2-inch piece of smaller vacuum hose to fit the vacuum port of the new valve; The S type's vacuum hose is 1/4", the CarQuest heater valve uses a 1/8" vacuum hose, that's why you need the splicer-reducer.
Old Dec 7, 2012 | 08:35 AM
Don S-Type's Avatar
Thanks, Jose!
Keep me in mind when you have a re-build source.
Old Dec 7, 2012 | 12:10 PM
Jose's Avatar
Originally Posted by Don S-Type
Thanks, Jose!
you bet Don, take a picture of your heater valve and post it here when you get a chance. The S type is the only Jaguar with that particular Heater valve.
Clare Jennings
Oct 4, 2015 05:43 PM
inactualis
Oct 2, 2015 11:13 AM
