Can the oil pump loose its 'prime'?
The pump must be worn or something sludged up. Your new oil will be a high detergent product & likely to loosen up a lot of gunk. Suggest you do another oil change at 1000 miles to drain all the suspended sludge out. You do not want a clogged oil filter to push the the engine into bypass.
Block the breather at the pipe that goes to the aircleaner/carb inlet. No need to remove the breather assembly from the front of head/chain case.
