Cylinder head
Old Apr 18, 2017 | 12:43 PM
Charlie1's Avatar
Default Cylinder head
Hi there, I have a brand new cylinder head with rocker box covers complete with new camshafts, these are all genuine jaguar parts and the cylinder head is dated 1965. I would like some help determine if it is for a 4.2l or a 3.8l straight 6, these are my grandfathers parts and he has past away unfortunately. If someone knew the part numbers to distinguish them, Many thanks.
charlie
Old Apr 18, 2017 | 01:35 PM
JeffR1's Avatar
It has the old style intake ports on it and water jacket, so it was never meant to go on a 4.2 litre engine.
It may bolt on the 4.2 litre block, but the intake manifold won't match at all.
Old Apr 20, 2017 | 03:30 AM
Jose's Avatar
on one of the front or rear slopes inside the valleys where the spark plugs are, there should be a number which shows the compression ratio, get a picture of that number, it probably is a 3.8 liter head.
Old Apr 20, 2017 | 07:54 AM
Charlie1's Avatar
Thanks for the reply and the only number present on the cylinder head valley is 'UK572' there are no compression ratios but is is a B type head.
Regards, Charlie
Old Apr 20, 2017 | 09:53 AM
Jose's Avatar
can you send me full pictures of it? the pictures you posted are cut at the points where some detail is needed to confirm. I'll send you my e-mail by PM.
Also, I do not see the camshafts, they are not installed, correct? or the cam covers?
thanks.
