Earth strap
Old Jun 4, 2015 | 12:33 PM
Hartford6's Avatar
Default Earth strap
Hi Chaps,
I have a Mk2 1962 3.8 Auto Positive earth and I am having a few teething problems.
So can anyone tell me where the earthing strap/cable is situated? I mean the one that connects the body to the engine as I cant find it............yet
Old Jun 4, 2015 | 02:15 PM
JeffR1's Avatar
If you're facing the car looking at the grill.
It's on your right front engine mount.
Underneath the generator...
Old Jun 5, 2015 | 05:31 AM
Hartford6's Avatar
Hi Jeff,
Thanks for your reply. I have taken a look and all I can see is the lead from the generator that disappears into the wing.
Am I looking in the wrong place ??
Best regards
Ian
Old Jun 5, 2015 | 07:43 AM
Jose's Avatar
in my 1965 S type there is no separate Earth/Ground Strap, one battery cable is connected to the body whether Pos. or Neg Ground.
Old Jun 5, 2015 | 10:44 AM
JeffR1's Avatar
Originally Posted by Hartford6
Hi Jeff,
Best regards
Ian
https://www.jaguarforums.com/forum/m...-issue-124458/
Click on the photo to make it bigger.
Have a look at the picture in post #4.
That engine mount is underneath the generator which makes the cable hard to see.
I don't know if that cable is original, but it is definitely a grounding cable running from the block to the body.
@ Jose: Hmmm, there has to be some sort of cable somewhere on your S Type to ground the block, otherwise how would the starter crank ?
With out the cable wouldn't the rubber engine mounts isolate the block from the positive/negative side of the battery ?
Old Jun 5, 2015 | 08:42 PM
Jose's Avatar
Originally Posted by JeffR1
@ Jose: Hmmm, there has to be some sort of cable somewhere on your S Type to ground the block, otherwise how would the starter crank ? With out the cable wouldn't the rubber engine mounts isolate the block from the positive/negative side of the battery ?
you are correct JeffR1, the S type DOES have a Earth Strap, so I stand corrected, I've just never seen it either.
reading my service manual engine removal instructions it states as follows:
"DISCONNECT THE EARTH STRAP FROM BODY AT REAR OF INLET MANIFOLD".
Old Jun 6, 2015 | 01:04 AM
Hartford6's Avatar
The picture says it all :-)
Many thanks for your help
Ian
Old Jun 10, 2015 | 06:14 AM
bazanaius's Avatar
Re-reading that post reminds me - does anyone know where I might order a new ground strap? Currently it's still the same 'temporary' fix I made at the time to re-clamp the strap in the bracket - it works OK but I'd like to replace with a properly clamped part.
cheers,
B
Old Jun 10, 2015 | 10:22 AM
Jose's Avatar
try SNG Barrat USA store or UK store,
SNG Barratt - The Ultimate Jaguar Parts Specialist
Old Jun 13, 2015 | 10:10 AM
Hartford6's Avatar
New Earth strap fitted.
Problem still not cured but that's one step closer to solving the problem.
Many thanks for all the help tho
Much appreciated
Ian
Old Jun 16, 2015 | 03:41 PM
bazanaius's Avatar
Thanks Jose - typically I did a search for 'ground strap' when I originally looked and so didn't find it...
Ordered! I hope you find the source of the problem Hartford.
B
Old Jun 16, 2015 | 04:39 PM
Jose's Avatar
that's because the English call it "Earth strap". not "Ground strap" as in the US.
FYI, the XJ-6 has a real nice stainless steel ground strap from the chassis to engine, and another one from the radio to the transmission tunnel.
Old Jun 18, 2015 | 02:14 AM
Hartford6's Avatar
B
I'm doing my best.................
jagent
Jun 5, 2022 02:18 PM
n8ertot
Oct 11, 2015 02:28 PM
JagBrian
Oct 1, 2015 12:52 AM
vacolorito
Sep 25, 2015 09:29 AM
