Engine mounts causing vibration?
Old Apr 27, 2023 | 01:40 AM
freddyuk's Avatar
I will talk to my contact at DM. I have attached a photo of my bracket which I know as Rear Engine Stabiliser. I was thinking the bracket you were referring to was underneath somewhere!
So the bushes in this stabiliser were both renewed. I cannot see the rear but guess it is the same bracket in the parts manual which only shows one such bracket.
The thread was adjusted so it was just snugged up to take the engine weight and then locked off.
Old Apr 27, 2023 | 03:53 AM
Glyn M Ruck's Avatar
The Rear Engine Stabaliser is common to all Jags of our era.
Old Apr 27, 2023 | 04:04 AM
Cass3958's Avatar
And a Biatch to get to on the Jaguar but seems from the photo very accessible on the Daimler V8.
Old Apr 27, 2023 | 05:02 AM
We managed along with some foul language. Is it any easier on the Auto with the larger tunnel or is the space eaten up by the larger bell housing for the flexplate & ring gear? As you say miles of space on the V8.
Old Apr 27, 2023 | 08:02 AM
Cass3958's Avatar
Auto is the same. No room as this is the back of the cam covers and heads that get in the way as the room between them and the bulk head is the issue. When I put the mount in with the engine I found it easier as the heater and the heater pipes were not in place but when I replaced mine a couple of years ago it was a real struggle to get down to the bottom bolt.
Old Apr 27, 2023 | 11:06 AM
freddyuk's Avatar
Do you have a Parts Manual? Do you know the part number?
If it is C22112 there is one on Ebay at present.
Non Jaguar spares are hard to come by for the Daimler V8
To clarify you were talking about a plate between the sump and bellhousing? This part number is for the Engine Stabiliser so I do indeed need to look under the car to see if I have the reinforcement bracket? I have no idea what part number this may be.....
Old Apr 27, 2023 | 11:28 AM
Yes as above which is a quote from James Taylor BTW in his latest Jaguar book which includes the compact Daimler V8.
Old Apr 27, 2023 | 01:46 PM
  #28
Peter3442's Avatar
There's a real need for a good photo or a spare parts book here (or someone who has one and can copy the relevant drawing). Once you know what it bolts to, it shouldn't be difficult to make something to perform the same function.
Old Apr 27, 2023 | 02:42 PM
hueyhoolihan's Avatar
FWIW, i've recently become familiar, too familiar AFAIC, with a "stabilizer". as it was very much in the way when replacing the steering rack on my '53 MG.
mine sits a bit higher on the block than the engine mounts and appears to moderate the amplitude of side-to-side motion.
Old Apr 27, 2023 | 03:24 PM
  #30
Indeed Peter. That's why I asked if the OP had a Parts Manual. I don't have a picture in my mind of what the darn thing looks like.
Old Apr 28, 2023 | 02:26 AM
  #31
freddyuk's Avatar
I have the parts manual although difficult to scan. I attach the relevant pages. All the rubber parts and bearing parts and UJ's on these images were replaced plus the engine mounts. I cannot see any additional items to perform a strengthening function. I did not fit these parts myself.
I have also investigated the tyres which I believe were fitted some years ago and whilst they have not done any mileage may require replacement anyway. I have looked but cannot see any date marks. They are Avon steel radials made in UK. The DOT code is CA347. That does not register anywhere I can find. There is no 4 digit date code.
File Type: pdf
Old Apr 28, 2023 | 03:07 AM
  #32
Peter3442's Avatar
So far there doesn't seem to be a sign of Taylor's strengthener/stiffener as a separate part. Is it possible the extra strengthening is a gusset in the casting (of the bell and/or gearbox case) rather than a bolted on bracket?
Old Apr 28, 2023 | 03:15 AM
  #33
Yes ~ That's what the Manners catalogue shows.
There is a thing at the front of the engine called a sump bridge piece. I don't know what Taylor is talking about.
No 75
Old Apr 28, 2023 | 03:29 AM
  #34
Peter3442's Avatar
It looks like something to retain a seal?
Old Apr 28, 2023 | 03:40 AM
  #35
Indeed! Daimler V8's are few & far apart in SA. I know of no one in Cape Town that I could crawl under. There is a silver one in Johannesburg I know of.
Old Apr 28, 2023 | 11:40 AM
  #36
Peter3442's Avatar
I think tyre date codes started about 1970 or 71, so there should be one some somewhere or these tyres have done incredibly well!
Old Apr 28, 2023 | 12:08 PM
  #37
Jagboi64's Avatar
If the centre bearing on the propshaft isn't in the proper alignment you can have vibration. It's caused by the driveline angles across the U joints being incorrect. There is usually a side to side adjustment on the centre bearing to enable getting the angles correct, plus shims to adjust the height. Ideally, the difference in compound angle ( the net angle calculated in both the horizontal and vertical planes) across each joint should be within 1°. For example, if the net angle across the joint at the differential is 1½°, then the others should fall in the 1½°-2½° range. The smaller the difference between the joints, the better.
Here is everything you never thought you needed to know about driveline angles! It's a good resource for setting up shafts and U joints though. https://www.waterousco.com/media/wys...311-1-DSSP.pdf
I doubt it's tires, as you said the car was smooth before and now it isn't after the work done, and the tires haven't changed. It's most likely due to the parts that were disturbed/replaced, rather than a tire spontaneously going bad.
Old Apr 28, 2023 | 12:20 PM
  #38
I think Peter is likely right. That Jaguar made a permanent change in a component & not a bolt on afterthought.
We should also remember that Daimler's ran split, as in two piece, propshafts IIRC. It's been a long time since I looked at one on a hoist. Hence JB's centre bearing comment.
Old Apr 28, 2023 | 12:46 PM
  #39
JeffR1's Avatar
I'm too lazy to read through the thread, so I'll put this out there.
Are the ends of the U-Joints in the same plane ? See photo.
And that's not good enough, things have to marked so they are not 180 degrees out from where they were.
About the centre engine support hanger, when I did mine, I snugged it up just to take up the slack, plus 1 flat, I virtually put none of the engine weight on it.
I thought putting too much engine weight on the support would start lifting the engine of its mounts, this in turn would cause the engine to move around and cause unwanted vibration.
I thought it was to take the torque of the engine, not so much the weight ?
It may also pull the back of the engine up enough to throw things out of alignment if tightened too much.
I totally agree with Jagboi about the tires.
Old Apr 28, 2023 | 12:56 PM
  #40
Jagboi64's Avatar
Yes, it won't take the weight of the engine, you'll rip the bracket off the firewall. It's just to dampen the side to side rocking of the engine.
