EZ power steering on a 3.8 S
#61
Received 1,366 Likes
#62
I would not buy an S Type any later than a late 1966 with a Powr-Lok limited-slip differential ~ later deleted from the 3.4. Mine was built January 1966. No 4 off our local production line at CDA, East London & personally inspected by Lyons to ensure it was up to Jaguar standards (registered before built ~ those things happened here which is why I call it a '65). Today Mercedes Benz state of the art plant is on the same site & we have just built our millionth Benz car.
Our engines & bodies were better built than any Browns Lane product. Pressed Steel did a poor job of bodies and our engines were built using the latest state of the art equipment for the era payed for by the SA Taxpayer. Browns Lane used old junk from Standard & the Daimler purchase. Bodies were built over bucks provided by Browns Lane & not Pressed Steel. Our local content program was in Phase 2 i.e. 55% by weight prior to moving to a value formula.
By the XJ6 bodies were pressed here by Steelmobile.
#63
Thanks for all your input, it is really helpful.
Saw the Golden Sand car again today but couldn't do the test drive because of really awful weather. Going back on Saturday for a drive.
It is in great condition, went round it with my magnet and all I can see/get to is solid. Wood is in great condition, engine started straight away (it was cold). General condition inside and out is better than the other car but as already mentioned this is a collectors car and the other has been driven. Door rubbers are not really rubber anymore but that is a minor detail.
It is missing its ID plate. When I asked the dealer he said that the owner does have it. I asked about the repeaters and apparently that is/was law in Italy (although it looks like a US import, need to do some more research) where the car was imported from 10 years ago. There the car was also part of a huge collection of cars owner by some dubious Italian "businessman" who went to jail and his collection was actioned by Southerby's (nice story anyway).
There is €4K difference in the asking price of the cars and I am pretty sure I can get the private seller of the maintained car down to €20K. I could probably get the car in the same condition in and out with the €5K. Such a shame the headlining has completely let go. Taking out the windscreen seems like a whole lot of pain and expense.
I need to go back and check out the maintained car again. I am going to take my time. If I need to wait for another one I will.
Just did some more research (well googled):
So part of the story matches.
I found it on the register. 1B 80311 DN
Glyn M Ruck (02-15-2024)
#64
Removing and replacing a windscreen isn't really a big deal, you will almost certainly need a new rubber (I would change it anyway unless the old one is almost new) and the best way to get the old screen out is to remove the chrome trim and then cut round the rubber from outside and then just lift the screen out.
Putting it back I use furniture polish (Mr Sheen!) as the silicone in it makes it really easy to get in.
Personally I would buy based on the condition of the body, the wood and the interior, I wouldn't worry to much about the mechanicals as long as it drives well, the engine has good oil pressure and the gearbox and over drive work and are nice and quiet. Things like the suspension, brakes, carbs, exhaust etc. are fairly simple to rebuild or replace as required (albeit the rear brakes are probably an axle out job). It all depends on what you are able to do yourself and what you have to send out.
The following 2 users liked this post by Homersimpson:
Glyn M Ruck (02-14-2024),
Peter3442 (02-14-2024)
#65
The following 2 users liked this post by Cass3958:
#66
#67
The only answer to the rear screen chrome cover is correct shaping and Loctite 480 & plenty of tape for a few days. It goes into a groove glass side but caps over the rubber body side. The windscreen is dead easy to take in and out. You have to take the windscreen out anyway because the Union Cloth lining has to go into the window rebate under the rubber or you end up with a mess as shown below.
Rear screen chrome PITA:
S-Type Owner (02-15-2024)
#68
#69
I've not found the rear screen chromes much trouble to install in the past on either my S-Type or my MK2s, all I do is put some blobs of PU adhesive on the back on them (after cleaning the rubber with some paint pre clean) and then fit it and use the holes at the end of each piece of chrome and a thin piece of wire (mig wire or strip a copper cable) to tie it together. After a day or two I just cut the wire off, fit the chrome covers over the join and its job done.
#70
I finally used COH Baines seals. They are a perfect fit both back & front. Dumped the others in the trash. LOCTITE® 480™ is a rubber toughened adhesive with increased flexibility and peel strength. It is expensive here but worth every cent.
https://coh-baines.co.uk/
#71
Cass3958 (02-16-2024)
#72
#73
I had my car & 2 donors. None of them had wiring holes under the centre chrome covers.
BTW ~ The COH Baines rubbers don't give you that lower front corner of the windscreen pullback issue that is so common. You still have to seat the bottom corners properly first though.
#74
#75
My 1966 S-Type had holes in the rear chrome trim, in fact I still have the original ones that came off it hung up in the garage as I replaced them with better ones.
I also have another pair although not sure what year they are off and they have holes in them.
It would of course be a simple task to put holes in if for some reason the car didn't have them, I would think it odd though if they didn't have any holes as I always thought thats how they suspended them to chrome them originally?
#76
#77
#78
#79
That's very interesting, I wonder why some don't have holes, were these made locally in SA or brought in from Coventry? My 59 MK2, 67 MK2, the 66 S-Type and the spare sets I have hanging up in the garage all have holes in them.
It would be simple to put the holes in if missing to make fitting easier and I don't think rust would be an issue as I thought these were chromed brass?
#80
They came from Browns Lane as part of the CKD kit. We did things like tropical radiators from Silverton, Upholstery, Engines, Batteries, suspension parts & springs etc. Our local content program was in Phase 2 i.e. 55% by weight before we went for a value based formula. If you look on Ebay some have and some don't. I have no idea why. The first time I learned about holes was on Rob's (Cass') 1967/'68 car on the Register.
By the XJ6, bodies were pressed here by Steelmobile. We are large steel producers. If they are brass corrosion would not be a major issue although even the window frames corrode & pit & they are brass.
