Front Shock Top Spacer
Old Oct 31, 2021 | 05:05 PM
paddyx350's Avatar
Default Front Shock Top Spacer
I'm ordering parts for the rebuild of my 420 front subframe suspension brakes and subframe.
There's a spacer/split ring that I removed from the top front shock mounting hole in the subframe turret to accommodate the M16 rod that I used to remove the springs. I think it's item 38 in the sketch in the attached PDF
I can't find this spacer listed separately anywhere on SNG or MR sites.
Does anybody know if it comes with a new shock? If not is it available anywhere?
File Type: pdf
Old Nov 1, 2021 | 07:36 PM
cdg66mk2's Avatar
I'm pretty sure that the new shocks (GAZ adjustable, in my case) came with new bushings and any spacers that you may need. I also removed mine to get the spring compressing rod down through the tower and I have at least one of them somewhere. I like to think that I didn't leave out a necessary part and it was clear that the new setup was all that was needed.
Kuddlesworth
Nov 5, 2021 02:23 AM
JaguarXKR
Apr 4, 2020 10:57 AM
apexjag
Sep 24, 2019 12:52 AM
michaelh
Aug 7, 2019 07:31 PM
amcdonal86
Jan 24, 2012 10:20 PM
