Head Gasket suggestions
Old Aug 28, 2022 | 05:05 PM
  #41
Cass3958's Avatar
Originally Posted by cdg66mk2
My new set of graduated cylinders arrived and I made my measurements this afternoon. 3.445 for the bore (just bored 0.020' over), flat of piston to deck is 0.006', volume with piston 1" down is 130cc and the combustion chamber is 99cc. Throw this all in the sheet and you get 9.02 with the std tin gasket and 8.72 with a 0.035 gasket. I guess I am a little surprised since both the head and block had material removed.
93 octane (R+m)/2 is readily available. Is a 9.02 compression acceptable? I'm still a little concerned with sealing with the std payon gasket. It the copper head gasket spray a good or bad idea?
Thanks again for all the input!!
I have after my engine rebuild in 2014 9:1 ratio pistons in my 3.4s which has been bored plus 40. My head was skimmed as well and although I have not done your maths my compression ratio must be quite high.I used the standard composite Payen gasket which came in a Gasket set from SNG. In the UK we have 95 and 97 ron unleaded at the pumps and I can run my car on either and not have any pinking or ignition problems. Our 95 ron is now 10% ethanol where as they have kept the 97 which is slightly more expensive at 5% ethanol so I tend to use the 97 Ron with 5% ethanol in my S Type with no problems.
Old Aug 28, 2022 | 05:22 PM
  #42
Jagboi64's Avatar
I think you should be ok. I have used both the stamped sheet metal gaskets and the composite gasket and both work. The sheetmetal gasket is fussier about a smoothly machined surface on the block and head, and the composite gasket is more forgiving.
EDIT: if it makes you feel more comfortable, then go with the standard thickness composite gasket. That will drop the compression a bit and give you a little more margin against detonation. 93 AKI is good fuel though. As a general rule, engines require less octane to not detonate as elevation increases and temperature decreases. So Denver in January will need less octane in the same engine than Houston in July.
Roberto Caria
Dec 4, 2023 01:01 AM
BadDog
Dec 3, 2021 06:47 PM
AnttiM
Apr 20, 2018 02:23 PM
hey_hej
Jun 3, 2008 10:16 PM
